Primeing oil pump
Primeing oil pump
I took my 327 out last year.switched to a different motor.now I’m putting my old motor back in.the motor sat for a year.put engine back in.went to prime oil pump to get oil up in engine.spun for about ten minutes on and off. No oil coming up to rockers . The engine had good oil pressure when I took it out. I did drain it out and put new oil and filter in.tried to convert to spin on filter but it leaked.so I put old canaster back on no leaks.before someone says something I put the spin on conversion kit on.so if anyone had this problem please help me out.
Received 1,568 Likes
If you want oil to the rockers, you need to use a primer tool that supplies oil to the lifters. I made one from an old distributor.
By any chance can u have someone look at the gauge in the car (assuming you hooked it all up?) just to verify if you are getting oil pressure at the gauge when using the drill?
I have not I will try that tomorrow. I am doing this by myself. I thought about that . But when you’re alone I can’t see the gauge.is there a certain way the oil fitting that mounts up in the block needs to be a certain way. I am talking about the piece that bolts on the block with two bolts. I’m using the canister like original engine.
I do realize you are a one man band so to speak I feel your pain, all my work today out in the garage is the same.. I asked about reading the oil gauge for pressure because I’m wondering if when you started out with an empty oil filter canister it may take some time to fill that sucker with the drill method & then continue with the drill to get oil pumped up to the rockers etc?
I usually fill that large canister first with fresh oil then screw it up into place (messy I know) to aid in instant oil pressure, I’m wondering if your oil filter canister is still not sufficiently filled yet in order to get oil upstairs? You could drop the canister down & see if you got oil in there?
If I’m following/reading your post correctly you did nothing but a glorified oil change to a motor that sat for some time?
** Frustrating I know keep with the basics, let us know if you got oil psi at the gauge when spinning the drill/priming tool (clockwise correct?), sorry had to ask?**
After spinning the oil pump for a while, did you rotate the engine. It's usually a case of spin, rotate a bit, spin again and so on till you see oil at the rockers.
Mike T - Prescott AZ
That pump moves a LOT of oil really fast so it should take only a few seconds to fill that oil filter.
Also, are you certain that the drill shaft has actually keyed onto the oil pump shaft correctly and is not merely spinning free down there?
Try to put you cel phone camera into movie mode---hang it in front of the oil pressure gauge --turn it on and let it run a movie while yu run the drill. That way you could at least see if you have pressure to the gauge.
Eddie
JF in MI (02-24-2024)
Would you be afraid to start engine. I am getting 40 lbs pressure with hand drill.but not getting oil to rockers. I put assembly lube on push rods.would that keep oil from getting through push rods.
I had to go back & read your post again, I’m still perplexed about the situation slightly, you did nothing wrong as I can see but change oil & filter, sorta like a barn find & you change some fluids & crank over car to check for oil press?
Good news is that your getting oil pressure, if you still don’t feel comfortable about starting the engine, you could always pull the coil wire & use the starter to crank it over some, no harm there & see if you are getting oil upstairs .
I’m thinking those lifters bleed down? Try the above no harm there.
I would be hesitant to start the engine. That oil pump moves A LOT of oil in a very short time. Sumpin aint right.
Could be that one of the INNER plugs is missing or became dislodged. That would explain it.
Keep checking.
Eddie
Pro Mechanic
Received 1,325 Likes
2023 C1 of the Year Finalist - Modified
I have to respectfully disagree. When I primed my engine, with hydraulic lifters, I had oil coming up through the push rods and rockers.
Keep checking.
Eddie
Keep checking.
Eddie
