C2 Distributor Differences
Old Aug 21, 2024 | 05:28 PM
INMYOWNBARNSINCE82's Avatar
INMYOWNBARNSINCE82
Default C2 Distributor Differences
I need a Distributor for a 63 Corvette 340 hp engine.
As the block and heads and intake are correct for 63, I would like the Distributor to also be correct.
Is there any above or below the manifold differences between a 63 Distributor Housing and the other C2 or early C3 years?
Last edited by INMYOWNBARNSINCE82; Aug 21, 2024 at 05:52 PM. Reason: Improved the question
Old Aug 21, 2024 | 06:12 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
The football shape weights, springs and vacuum advance can differ from different engine variations
Old Aug 21, 2024 | 08:05 PM
pop23235's Avatar
pop23235
Once the aluminum band is gone, there is little way to know what a distributor originally came on.
Old Aug 21, 2024 | 08:30 PM
anyChevy's Avatar
anyChevy
As above, springs and weights.
Any SBC or BBC tach drive distributor will work
Old Aug 21, 2024 | 09:38 PM
GCD1962's Avatar
GCD1962
62' 340 hp had the dual point version, That tach is one of the most desired
Old Aug 21, 2024 | 09:48 PM
kts1962's Avatar
kts1962
In addition to elements in above posts , it is key to make sure the slot in pole piece that limits mechanical advance is correct.
the underside should be marked with ‘CCW’ and a 3 digit number indicating advance. For my L79 it’s CCW 530 for 30* of mech advance.
for the ‘63 L76 340; mech advance was 24* so the pole piece would be marked something like CCW 524. These are all Internal Differences so I’m not sure how much it would matter to you.
Old Aug 22, 2024 | 08:31 AM
tbarb's Avatar
tbarb
The 1963 distributor football on top of the main shaft should be stamped 54 and the rotating weight base cam is stamped CCW 724, weights are stamped 37. The vacuum advance control is stamped 201-15.
Old Aug 22, 2024 | 08:44 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
BUUUUUUUUUT, it does not have a vacuum advance, which in my book, makes a car more practical for town and city cruising.
If some just gots to have a 985 distributor, I gots one.
Old Aug 22, 2024 | 12:03 PM
pop23235's Avatar
pop23235
Tbarb, you wouldn’t happen to have this information on both 64 distributions would ya?
Old Aug 22, 2024 | 06:29 PM
tbarb's Avatar
tbarb
I don't have the exact specs for the 1964 distributors but I will look and see what I can find. If you belong to the NCRS and do a search on their discussion board the info may be there. I know the shp engines used a more suited (faster) curve.
Old Aug 22, 2024 | 09:54 PM
kts1962's Avatar
kts1962
This from GM Heritage will have the basics. But not stampings on specific parts…
To C2 Distributor Differences
