Whats the proper casting #??
Old Apr 7, 2005 | 04:17 PM
68sbShark's Avatar
68sbShark
Default Whats the proper casting #??
I can't seem to find the proper casting # for a water pump for a '68 327/350hp. Dont know if it makes a difference, but it is a late '68.
I've checked all the regular casting number sites recommended here, but none of them seem to have water pump castings.
Thanks,
~Rich
Old Apr 7, 2005 | 04:24 PM
luerja's Avatar
luerja
found something for you...hope this helps
Water Pumps
Casting # 3782608 (1963-1972 327 & 350)
Casting # 3856284 (1966-1969 427)
Casting # 3969811 (1970-1971 454)
Casting # 3992077 (1972 454)
Old Apr 7, 2005 | 04:32 PM
68sbShark's Avatar
68sbShark
Water Pumps
Thanks for the quick reply.
I've seen that number before (top one for 327) and it has always said "not for the L79", which is what I have.
I have found 3859326, which is for a 66-67 327/L79 but nothing for a '68.
Where did you get the info??
~Rich
Old Apr 7, 2005 | 04:53 PM
luerja's Avatar
luerja
I just happen to remember I had seen water pumps there.
http://www.geocities.com/vette6769/g...s-for-sale.htm
Old Apr 7, 2005 | 05:01 PM
68sbShark's Avatar
68sbShark
That site is a mirror for lightningspeedshop. I saw that site as well, but after trying to cross the numbers, they didnt match.
Are all of the correct casting numbers in the AIM? One is on the way in the mail. I have never seen what is actually in the AIM, so I'm anxiosly awaiting its arrival.
~Rich
Old Apr 7, 2005 | 10:34 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
~Rich
Rich, just pulled the water pump off of my MOSTLY ORIGINAL 42k mile March 19 build L-79 '68 Corvette #14222 minutes ago, and it is INDEED #3782608 with a date of "A 4 8", which is January 4, '68.
Old Apr 8, 2005 | 10:15 AM
68sbShark's Avatar
68sbShark
Thanks for the info. For some reason I thought there was a hi performance water pump for the 327/350hp that differed from the base 327.
Anyway, I thought I had the wrong pump on the motor, but I guess it is correct. The only problem is it is beginning to leak from the pump shaft. I can't seem to find a rebuild kit for these. Any suggestions where to locate one? Or is it best to just get a new AC Delco and replace it?
~Rich
To Whats the proper casting #??
