Quick fixes
Old May 9, 2005 | 12:36 AM
Fstdraw's Avatar
Fstdraw
Default Quick fixes
Hope i've got this in the right forum. I've taken the small block out of our '69 coupe. The motor will be out of the car only 3 or 4 days. What can I do in short order to spruce things up a bit( in the engine bay) before I install the new 406? The car has the typical underhood problems all Vettes do, power steering fluid on things, replaced non-stock parts here and there, the black engine compartment paint worn off. I'm going to service the 4sp and repaint the bell housing, but could use advice on things to fix up or at least pay some attention to. Thanks in advance for the suggestions.
Old May 9, 2005 | 07:08 AM
fast idle's Avatar
fast idle
a scrub brush with some paint thinner will get most of the grease and grime off and have it ready to paint.
tidy up wiring harnesses by re-wraping them with the plastic protector tubing. tuck away any unused leads (old a/c wires etc)
if you are painting use a semi gloss not a gloss,and be sure to cover any thing you don't want painted, it takes about two days but it will make it look 100 percent better.
Old May 9, 2005 | 08:05 AM
ICEMAN59's Avatar
ICEMAN59
If you have time before the process starts order POR-15's kit it has degreaser, etching prep, primer and top coat. I did my engine bay and undercaridge in three days, you can see pics in MYCorvettte pics under my avatar.
Hope this helps,
The iceman
Keith.
Old May 9, 2005 | 08:29 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i wanted a contrast since i had ablack vette and a black engine so i went with a different color for the eninge bay
[IMG][/IMG]
[IMG][/IMG]
To Quick fixes
