U-Joint removal at Diff
Old May 20, 2005 | 11:03 AM
C3nMe's Avatar
C3nMe
Default U-Joint removal at Diff
My C3 is showing a little age in the suspension department, and I have at least one failing u-joint (it spits out grease like a spoiled 1 year old spits out strained carrots).
The problem I have is trying to find the trick for getting the bolts off the u-joint bolts closest to the differential. Anyone have an expertise or suggestions how to defeat it? It's a 77 and the bolts are pretty heavily rusted ..
Thanks in advance.
Brian.
Old May 20, 2005 | 11:05 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Best thing is a box end 9/16" ratchet wrench
Old May 20, 2005 | 01:07 PM
stingraymaniac's Avatar
stingraymaniac
did mine last weekend but i hadnt that much rust on them.
i turned the axle so i could get the best torque to get the nust loose,went great i had it on the bench after 20 mins
just get the box end firmly on the nut so you dont slip and damage the
nut and spray it with rust penetrating oil before you start also
Old May 20, 2005 | 02:30 PM
C3nMe's Avatar
C3nMe
I hope that the several "pre-treatments" of a product I use called "PB Blaster" penetrating oil will help alleve some of the friction there ...
I don't have the option of using the e-brake to hold the wheels ...was putting it in gear enough to keep it from turning while you torqued on it?
Old May 20, 2005 | 02:47 PM
C3nMe's Avatar
C3nMe
Sounds like a great idea ...I've been wanting to try one of those.
Old May 20, 2005 | 03:35 PM
stingraymaniac
Have it in gear and it will stay.
I got under my car without having the wheels in the air and loosen all the bolts first,then i raised it and took the shaft out
Old May 20, 2005 | 05:02 PM
C3nMe's Avatar
C3nMe
That would have been clever, but I ended up down this path long after I already had all the wheels off and was busily doing other work.
Darn my frail human body!
Old May 20, 2005 | 06:20 PM
mandm1200's Avatar
mandm1200
Not sure i follow what is giving you the problem or what you have. Are the nuts the problem or is getting the 'U" bolt out of the yoke the problem. The nuts on mine were quite easy, but I did have trouble with 1 U bolt on the drivers side. I soaked it with WD40 and found a place where the nut hit the differential and I was able to back off the nut so it would push the U bolt out some what. Then resoaked it, tighten the nut, repeated the above several more times and finally the U bolt came out. The U bolt has to come out evenly, which you probably already realise. I did over-torque the nut trying to get it off, but I had new U bolts to put back in.
Old May 21, 2005 | 09:43 AM
C3nMe's Avatar
C3nMe
Right now, I haven't been able to get the nuts to budge. I'm picking up the replacement parts today and I hope to have time this afternoon to make another go at it. Your statement did make me realize something ...new u-joints probably don't come with new u-bolts. Ugh!
Brian.
Old May 21, 2005 | 01:09 PM
rcread's Avatar
rcread
Once I got the wrench on the nut, I took a breaker bar, wedged one end against the differential, and used it as a lever on the wrench. Just make sure you protect your knuckles so you don't ram them against suspension pieces when the nut lets loose.
To U-Joint removal at Diff
