weatherstripping help
Old May 24, 2005 | 09:51 PM
onaqwst's Avatar
onaqwst
Default weatherstripping help
i'm trying to put on my ttop weatherstripping and it seems to be too big for the top..... i ordered the right set for the whole car..... also seems as if the tab hole are a little off so i had to pull the ws a bit so now i have about an inch of slack now...... i might just cut it and silicone glue it..... any suggestions....... i'm getting at my last nerve with this car......
b
Old May 25, 2005 | 08:15 AM
texaswilkins's Avatar
texaswilkins
I just did all of them and mine all seemed just a little too small. I pulled it just a bit and they all fit right. They all are very tight and after sitting for about a month now in the hot Texas weather are getting a little better to deal with.
I wouldn't cut it. Check with your supplier to make sure it's the right one.
Bill
Old May 25, 2005 | 12:03 PM
onaqwst's Avatar
onaqwst
what a pain..... seriously.... makes me want to throw something.... we'll see if it will work when i am finished....
b
Old May 25, 2005 | 12:20 PM
67tripwr's Avatar
67tripwr
If you did not buy from Corvette Rubber, you could be making a big mistake!
Old May 25, 2005 | 12:49 PM
onaqwst's Avatar
onaqwst
i don't think i did...... it's been sitting around for a year or so in the package...... it's a cruiser car and won't be seeing any rain so i hope i'm fine
b
Old May 25, 2005 | 07:33 PM
ESU's Avatar
ESU
Bought mine from Mid america motor works, 79 coupe, fit perfect. Used the release agent for the old glue and 3m weatherstripping glue. Worked like a charm. Only problem was thet were alot thicker than the old ones and a bitch to get on. I had to loosen all the brackets and then tighten them up once the top was in place, trying to compress the rubber a tad so they fit easier.\
Esu in NY
To weatherstripping help
