Finished Spreader Bar
Old May 30, 2005 | 02:04 PM
84rzv500r's Avatar
84rzv500r
Default Finished Spreader Bar
Finished Spreader Bar, well almost. I need to get two nuts and two 1/2" stainless allen head cap screws. so that I can put it together.
More Pics on my corvette photos gallery...
Old May 30, 2005 | 02:07 PM
Nate '69's Avatar
Nate '69
Looks good! I'll be doing the same project soon.
Old May 30, 2005 | 02:10 PM
stingraymaniac's Avatar
stingraymaniac
nice!
Old May 30, 2005 | 02:45 PM
84rzv500r's Avatar
84rzv500r
It must be something to do with the bonehead DOG
Old May 30, 2005 | 02:49 PM
norvalwilhelm's Avatar
norvalwilhelm
Very nice job. I would love to do one but I just don't have the room.
Old May 30, 2005 | 03:21 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Good job on the spreader bar. I have one in my vert and it did make a difference. Yours will be even better since you have made it yourself.
Old May 30, 2005 | 04:32 PM
NHvette's Avatar
NHvette
Looks great. I like the U channel you used ... looks strong.
One question: I notice you placed the bar centered over the
front control arm stud. Any reason ? I was going to fab mine
with the bar more rear-ward to distribute the force to both studs.
Of course, the bar running front-rear would need to be suffiiciently strong to not flex.
Old May 30, 2005 | 06:16 PM
84rzv500r's Avatar
84rzv500r
The U channel should be as strong as 0.250 bar and a bit less hefty.
There is not much room to move the bar back between the studs. I have about 3/4 inches clearace to the belts. I used a gusset back to half way between the studs and that just clears. I had to relocate my alternator mount upward and still had to clearnace the bracket on the alternator side.
I still need to bore out a 1" nut on the lathe, split it and weld it to the shaft to have something to turn the shaft with.
Old May 30, 2005 | 06:18 PM
Gordonm's Avatar
Gordonm
I have mine about in also. I put in the electric fan at the same time. Just have to wire it up and put on the finishing touches.
Old May 30, 2005 | 08:00 PM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
Nice work.
Why not just machine flats in the bar?
Old May 30, 2005 | 09:35 PM
84rzv500r's Avatar
84rzv500r
Originally Posted by MrForce
Nice work.
I'm not that good of machinest.
The spreader is made up of the 1/2" rod ends and a piece of 7/8" x 0.065" 4130 tubing with the threaded sleeves welded to it.
Old May 30, 2005 | 10:27 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
This might be a silly question but why would you want to weld a nut on it to be able to adjust it? It seems that when you put it on and adjust it for tension you would leave it there.
Old May 30, 2005 | 11:02 PM
84rzv500r's Avatar
84rzv500r
I suppose a pipe wrench, or vice grips would work to hold the shaft whilst tightning the lock nuts but they mar the metal so...
I may still drill and saftey wire to keep things from moving when I dont want them to.
I preloaded it in compression to counter the force that I expect to be there during braking or cornering on that superspeedway...
Old May 31, 2005 | 12:06 AM
1971corvette's Avatar
1971corvette
[QUOTE=SHAKERATTLEROLL]This might be a silly question but why would you want to weld a nut on it to be able to adjust it? It seems that when you put it on and adjust it for tension you would leave it there.
seems they do it a little different up north,might be due to the long cold weather.
Old May 31, 2005 | 01:29 AM
SHAKERATTLEROLL
1971 Corvette are you trying to say Brain Freeze lol.
But really I would just load it and get the bolts tite and leave it. As it is not something that moves.
Old May 31, 2005 | 03:52 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
I wanna add one of those one day, your homemade one looks great
Love the dually burb, they did a nice job on the fenders molding it to the rear door handles.
Old May 31, 2005 | 10:45 AM
NHvette's Avatar
NHvette
Yeah - but anybody who has adjustable rear strut rods knows that they
can work loose. You gotta CRANK those lock nuts solid.
Thus, the big nut to pull against.
I didn't notice the gussets in the back ... I think you've convinced me.
Nice job
To Finished Spreader Bar
Old May 31, 2005 | 02:57 PM
VBP's Avatar
VBP
St. Jude Donor '07,'13
“Finished Spreader Bar, well almost. I need to get two nuts and two 1/2" stainless Allen head cap screws so that I can put it together.”
We’ve got the jam nuts and possibly the Allen head cap screws on the shelf. You would need to call and ask a tech Gary or Robin to be sure… You’re setup looks very good…
Alan G.
Vette Brakes & Products, Inc.
800-237-9991
Old Jul 18, 2005 | 11:27 AM
Fevre's Avatar
Fevre
Have not drove my vert vette in a while and first things I noticed was how much flex I could feel, need to spreader bar ASAP.
Put my male boxer down in Dec, had a nasal tumor.
Old Jul 18, 2005 | 12:22 PM
Techno's Avatar
Techno
Whats it do? whats it for?
