Paint Stripper
You also don't have to get every nook and cranny spot. You can sand some too, use every method where needed.
Guess I will try the hood tomorrow. Just seems like I have now created alot of fill and sand bodywork?
Here's what I found worked for my 1982 this morning. It has 3 layers of paint. Looks as if originally the car was Charcoal Metallic, then someone painted it Dark Red, and lastly Bright Red with a clear coat.
I used the razor blade method to scrape the clear coat and then my 6" orbital air sander with 100 grit to knock down the 3 layers of paint to the gelcoat.
Probably wasn't having alot of success with the razor blade on the paint due to the build up of layers?
TAKE IT FROM A PAINTER!
No matter what the product labal says, it is NOT meant to be used on anything but metal.
If you run into a problem area working from a stripped edge helps. The razor is on the ground working against that raised edge.
If you do gouge too much a lower angle and shorter strokes help your control of it.
I had spots where a 2' stroke X 2" wide shattered right off and just kept going.
I found the corner of the blade liked to dig in and if the wrong angle you got chatter and this did a bit of digging.
Sorry, but I've stripped my car completly twice and I just got done stripping and repainting the hood and t-tops. My paint job is 15 years old and I've had zero problems with it and it's lacquer which is problematic in itself. If you follow good procedures and neutralize and wash the surface after you're done you won't have any problems. Fiberglass strippers weren't just invented for corvettes. They are used in boat and aircraft refinishing also. If they were that bad I don't think they would be on the market very long. I see all of you guys attacking a plastic car with a razor blade. Don't you think that's a little more damaging than using a product that was made for the job???????? To each his own but if you gouge your bodywork you'll soon find how difficult it is to repair without problems like swelling and cracking down the road. BTW here's a 15 year old chemically stripped fender.
The clear is coming off in long (sometimes 2') long strips but the paint is on like glue! I think the last person that painted the car, must have scuffed the surface and this may be why.
That is one sweet looking close up of your Vette's fender. Caught the angle, reflection, and light just right.
A: You don't have ANY breaks through the top "Gel-coat". Since you have to wash the stripper off, if you do have breaks, water WILL be absorbed into the fiberglass. Now, if you let the water dry out for several days, preferably 10, in low humidity, you may be lucky enough to have no moisture to trap under the primer. If you live in Houston, forget about it drying out.
B: The stripper finds itself trapped in every nook and cranny. You must be meticulus about removing every trace! If not rinsed out, it will remain dormant until re-activated by primer solvent, moisture and/or heat. The question is: How lucky are you? We do use it on piece-parts like headlamp bezels, cowl vents and anything metal....My 25 cents worth....G/L
There is no gelcoat on the unfinished side of your body and water isn't absorbed through that side.
Gelcoat is polyester resin thickened with any number of powders, talcum powder is one of them. silica is another, try sanding that!
Fiberglass is strands of glass encapsuled in polyester resin.
Where is the big difference here?
Now if you still believe violating the surface skin of gelcoat is going to absolutly ruin your fiberglass body consider what happens when the gelcoat cracks on a boat. It isn't destroyed. It isn't even destroyed when the crack runs clear through the fiberglass to the other side. This is a vehicle that most definately was exposed to water
The funny thing is water isn't absorbed by fiberglass too well. Both the glass on your house and the milk bottle in your frig seem to repel water not absorb it.But when it becomes a Vette body it becomes a sponge.
There is too much mystique around these fiberglass bodies.
The problem with stripper is if you allow it to strip polyester resin, it will. Your not supposed to do that
And its a whole lot more work to chemical strip polyester resin too. If you wanted to do it- it would take forever.
