line lock
Old Jul 31, 2005 | 06:33 AM
john1977's Avatar
john1977
Default line lock
Is anyone using a line lock on there vette and if so where do you get one? Have looked in summit but they dont list one for a vette. Also how much trouble is it to install?
Old Jul 31, 2005 | 06:52 AM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Seen a post about a line lock install either on this fourm or cac.
Do a search on Line lock & see what comes up.
Old Jul 31, 2005 | 09:47 AM
PRNDL's Avatar
PRNDL
I got mine from Summit. Can't recommend the installation kit. If you have a Napa nearby you can get all the fittings and brake lines you need there. Used it for the first time yesterday - worked great!
here is my detailed installation thread - with pics
http://forums.corvetteforum.com/show...0&forum_id=119
Old Jul 31, 2005 | 10:21 AM
motorpsycho502's Avatar
motorpsycho502
Check the photos in my sig if you want to see what a line lock does. I have the button mounted on the side of the shifter so you can hold it with your thumb. I also installed it a little different. the directions say to plumb it to hold the front brake pessure while pressing the button (allowing you to relase the brake pedal). this is a more difficult way to plumb it. so I simply put it in line with the rear brake line. The disadvantage is that this method block the pressure from reaching the back, meaning you must hold the pedal and the button at the same time. You also have to install the valve backwards due to the internal check valve in the solenoid valve. The end result is still a BIG burnout witout having to stress the trans/brakes so much.
Old Jul 31, 2005 | 12:59 PM
PRNDL's Avatar
PRNDL
motorpsycho - I had to read your post twice to figure out WTF you were talking about!! At first it sounded to me as if you were totally defeating the purpose of a linelock. Installing it on the rear and still using your brake pedal??? The entire purpose of the linelock for me is so I don't have to use the brake pedal, and it keeps my rear brakes off. I have a 4spd. BUT, I figured out you must have an automatic trans, so using the brake pedal is no problem, and you use the linelock to keep pressure AWAY from the rear brakes. I get it now! and I guess that is a reasonable way to install and use a linelock with an automatic trans.
To line lock
