Alarm problems...
Old Aug 14, 2005 | 08:39 PM
'73 Stingray's Avatar
'73 Stingray
Default Alarm problems...
The stock alarm on my '73 is sounding whenever the system is armed. I am pretty sure the posts in the doors and hood are not shorting. Is there anything else it could be, any checks?
Thanks,
Scott
Old Aug 14, 2005 | 09:04 PM
redwingvette's Avatar
redwingvette
The alarm switches are mounted in the rear post and can be accessed by removing the cover found inside the rear wheel well. Try pushing in on the switches with the doors open to see if they might need to be readjusted. It may be that the doors aren't pushing them in far enough to break the circut. Same goes for the hood switch. When the doors or the hood are openned it creates a ground to activate the alarm relay.
Good luck.
Old Aug 15, 2005 | 02:08 PM
'73 Stingray
I read somewhere that the tampering switch behing the key cylinder causes this problem, is there any way to bypass this to check?
Old Aug 15, 2005 | 04:01 PM
RMS73's Avatar
RMS73
There is no tampering switch on the 73's. when I get home I'll email you my spreadsheet for troubleshooting and schematic.
Roger
Old Aug 15, 2005 | 04:29 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
How about the t-tops......on an 82 I had the t-tops were alarmed.
Old Aug 15, 2005 | 05:02 PM
'73 Stingray
No t-top alarms...
Thanks Roger, that would be greatly appreciated.
To Alarm problems...
