Polishing the engine block
Old Aug 30, 2005 | 01:10 PM
GDaina's Avatar
GDaina
Get a die grinder and packs of emery rolls, some rough, intermediate and fine...use the rough paper rolls to get the block smooth, then the intermediate to get the scratches out, and finally the fine to polish.
Get some POR 15 engine paint, you won't believe the finish. You can thin the POR and apply it with a brush, or get a cheap spray gun...either compressed or airless will work.
The money you'll have invested in the tools and paint will be chump change compared to the 1500 to have it done.
Old Aug 30, 2005 | 01:32 PM
hill3335lilo's Avatar
hill3335lilo
Default Will this work on an LS2 as well?
With the aluminum block?
Thanks.
Dave
Old Aug 30, 2005 | 01:35 PM
hill3335lilo
Default Any pictures of painted blocks using POR?
Black or Aluminum color would be most interesting, but any color will do.
Old Aug 30, 2005 | 01:40 PM
Red 69's Avatar
Red 69
It is common to debur the inside of the block, open up entrance to oil return and polish the lifter valley. Try that first and multiply it by the increased area of the outside and you will have an idea of what it takes. It is a labor of love, if you are not motivated, don't bother. Time is better spent porting the heads IMO. For the outside you can start with a 4 1/2 inch angle grinder and work your way down to a die grinder with rolled abrasive. This is with an iron block. Aluminum is a PITA because it builds on your abrasive wheels and needs another approach. After doing my inside, I started on the outside, but settled on less than what I had in mind for the reasons already mentioned. A smooth block looks good, but is less efficient in dissipating heat, something to keep in mind. It is definately a point of detail for a show car, but everything else better be in harmony with it. In other words, an exceptional engine could make the rest of the car look bad.
Old Aug 30, 2005 | 01:45 PM
hill3335lilo
Default What is the 'other approach' for an aluminum block?
That is what I am going with...
Old Aug 30, 2005 | 02:23 PM
vette70's Avatar
vette70
Default Looks like maybe paint to me
Are you sure that block is polished. looks like a light gold paint on the block to me. With that much chrome on the engine can't see much of the block anyway.
Old Aug 30, 2005 | 02:30 PM
hill3335lilo
Default Not certain, but believe so
I have ruled polishing the block out now, due to expense/maintenance issues (and the fact that you can't really see much of the block). I'm now considering painting it. Any tips?
Old Aug 30, 2005 | 03:01 PM
GDaina's Avatar
GDaina
Ooops forget it...that applies to an iron block...
Old Aug 31, 2005 | 03:06 PM
Red 69's Avatar
Red 69
When grinding aluminum with closed coat paper keep it sprayed with WD-40. It keep the aluminum from building up in the abrasive. On your carbide cutting bits and rotary files, keep wax in the cutters, it helps keep the aluminum fron building up and cutters clean. A file card and wire brush will also come in handy. Like I said, it is a PITA.
