Timing light "digital" vs "adjustable"
Old Sep 11, 2005 | 11:14 PM
71LS5's Avatar
71LS5
St. Jude Contributor
Default Timing light "digital" vs "adjustable"
I need to get a new timing light. I have had an hard time setting exact timing due to the timing marker is obscure from veiw in my engine.
I understand that an adjustable light will allow me to dial in a degree or so at a time but what will a digital buy me? what does it read?
Old Sep 11, 2005 | 11:17 PM
big_G's Avatar
big_G
Digital will lighten your wallet...they operate the same...$70 or $200...your choice
Old Sep 11, 2005 | 11:19 PM
greyghost79's Avatar
greyghost79
be sure its got the adjustment dial. used a non adjustable for years. never realized how much easier (and faster) the job goes with an adjustable timing light.
Old Sep 12, 2005 | 06:21 AM
fl_rider's Avatar
fl_rider
Default Just a question?
If you cant see the timing mark how is a different timing light going to make it better?
With the adjustable light you set the desired timing (12*) and then when it flashes the timing mark on the damper should line up with the 0 mark on the timing tab when you have adjusted the distributor accordingly.
In other words you still need to be able to see the timing mark and indicator.
Some white paint in the timing mark will help to make it more visible. Use a toothpick or a very fine brush to apply the paint.
Chris B
Old Sep 12, 2005 | 08:51 AM
lars's Avatar
lars
The adjustable analog lights will do everything you need to get done for about $69. The digital lights will also give you rpm info, dwell, and other info, depending on the light. They'll set you back around $150 - $200.
Old Sep 12, 2005 | 09:16 AM
Stewart's74's Avatar
Stewart's74
I have a Matco adjustable timing light and am very happy with it.
I dont know how to use it. or tune my car, but I am very happy with it....
Old Sep 12, 2005 | 12:13 PM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
Well perhaps Lars can teach you how to use it in a couple weeks.
If not you can always give it to me. The old antique non-adjustable one I'm using works fine, but I've been looking for an upgrade.
Tell you what, I'll trade you for a video of your car being tuned. Then you will remember how to use it.
See you in a couple weeks.
Old Sep 12, 2005 | 12:36 PM
1971corvette's Avatar
1971corvette
I like an honest person.
Old Sep 12, 2005 | 02:31 PM
ThereIsNoSpoon's Avatar
ThereIsNoSpoon
To Timing light "digital" vs "adjustable"
