What MPG do you get?
Old Sep 19, 2005 | 05:45 PM
  #41
fl_rider's Avatar
fl_rider
Originally Posted by Scottys78
Ok….. Not to sound stupid but, how do you know what mpg you are getting?
1. Start with a full tank
2. Set the trip odometer to 0
3. Drive around until you need gas (no particular destination is OK)
4. Fill er up
5. How many Gallons did it take?
6. Look at the odometer
7. How many miles did you go?
8. Miles divided by gallons = MPG
EG: 300 miles / 15 Gallons = 20 MPG
but only if I coast a lot and it's mostly downhill...
Old Sep 19, 2005 | 06:42 PM
  #42
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
Originally Posted by Buzzardz_vette
My first long trip with the finished engine was to Carlisle and I avg'd about 19 MPG (18.8). How does this compare with other vettes?
I have the stock 350 CSB in my 76. It has an Edelbrock Performer carb on a Professional Products Cylone Plus intake and a Crane Cam (262 int./268 exh; 0.446 int./0.459 exh. lift), March underdrive pulleys; top rebuild with big valves.
I'm running a 383...350 gears. 15 mph while pulling some hills in No. Arkansas. Hope to get close to 20 on the Xpressway. Larry
Old Sep 19, 2005 | 07:16 PM
  #43
Scottys78's Avatar
Scottys78
4. Fill er up
Thanks, now I'm going to go out and find out what my Vettes mpg is.
Old Sep 19, 2005 | 08:54 PM
  #44
Techno's Avatar
Techno
Take a look at my list. hose are actual figures from tank to tank.
If I did it that way then I choose 31 mpg. Doing a single tank of gas is really loose on being accurate.
This method also requires an accurate speedo and with non 70 series tires its off something. I don't know how much? Any solid numbers on that?
  #45
C3nMe's Avatar
C3nMe
I'm getting about 14.6 on average, and I use software to keep track of it (called Automotive Wolf). I don't have a lot of data to generate a "decent" average, but for some reason I get the feeling the value is low.
I'm running a 4spd L48 1977.
Brian.
Old Sep 19, 2005 | 11:04 PM
  #46
Robert Hall's Avatar
0Robert Hall
Former Vendor
Default A Keisler 5 or 6 speed would sure help with mileage!
A 25% increase in mileage ads up fast at $3.00 / gallon!
You'd have to buy gas at $2.25 (25% less) to have the same Miles Per Dollar (MP$) with a 4 speed!
... so if you are saving an equivalent of 75 cents per gallon, a $2,995 TKO600 would pay for itself in 4000 miles That would be a good way to explain it to your wife. You're saving money by buying a Keisler 5 speed! If you drive enough you could save enough to retire or buy a really nice crate motor
Robert at Keisler
423-773-9789
Old Sep 20, 2005 | 07:00 AM
  #47
Spike-74's Avatar
Spike-74
I average 14 mpg.
Going to Carlisle last month I got 16 mpg while AVERAGING 80 mph.
So much for the theory of lower mph=better mpg. That myth is BUSTED.
Old Sep 20, 2005 | 09:17 AM
  #48
Sarge81's Avatar
Sarge81
I get around 15 city. And around 20 mpg hwy., at speeds of 75-80 mph with the '81. And with the A/C on.
The engine is a 350 w/Q-jet, LT4 HotCam,Vortec heads,full length headers,true duals w/cats. Richmond 4 spd., 3.08 rearend.
Darryl
Old Sep 20, 2005 | 10:50 AM
  #49
Buzzardz_vette's Avatar
Buzzardz_vette
Darryl
I was averaging 65mph on the highway. Maybe I should just bump that up to 75-80. Seems you get better gas milage.
Old Sep 20, 2005 | 10:51 AM
  #50
Buzzardz_vette
Robert at Keisler
423-773-9789
Were you at Carlisle? I remember seeing a 5-speed someone was selling.
Old Sep 20, 2005 | 11:04 PM
  #51
0Robert Hall
Former Vendor
Default Carlilse - I was There !
Yes Sir !
I was there telling everyone how great it is to have a Keisler Engineered 5 speed !
Robert - The Driven Man - Hall
423-773-9789
Old Sep 20, 2005 | 11:15 PM
  #52
PortDawg's Avatar
PortDawg
St. Jude Donor '05
MPG ? Who cares...it's a Vette...!
Old Sep 20, 2005 | 11:39 PM
  #53
collectskulls's Avatar
collectskulls
Old Sep 21, 2005 | 09:40 AM
  #54
Buzzardz_vette
Leave it to PortDawg to state the obvious.. I just like to know how my vette is operating compared to others.
Old Sep 21, 2005 | 09:59 AM
  #55
SuprJames's Avatar
SuprJames
My '82 gets about 20 mpg on the highway and 15 mpg around town with a stroker motor, aftermarket EFI, 4L60 tranny, 3.45:1 gears, and a heavy foot.
I can't wait to see what the '72 will get with a maggie blown LS6 with the 6 speed tremec and 3.45:1 gears.
Old Sep 21, 2005 | 10:17 AM
  #56
L88's Avatar
L88
I get 12-14 around town & 16-18 cruising. It went up after I installed the TKO-600 from Chevy 5 speed. Running a 454 W/3.70 rear. Using an Edelboock Performer 750. Switched to a speed demom 750 double pumper & the mileage went down 20%..., but the performace was much better.
Old Sep 21, 2005 | 03:24 PM
  #57
PortDawg's Avatar
PortDawg
St. Jude Donor '05
That's me...MASTER of the obvious...
