Katrina got my vette
Old Sep 17, 2005 | 08:48 PM
71rdster's Avatar
71rdster
Sorry about your losses, car home and I'm sure much more. I know there is much more on your mind than your Vette. And whether or not insurance is an issue with your car, insurance usually does not cover a really special car.
good luck
Orville
Old Sep 17, 2005 | 08:59 PM
litevette's Avatar
litevette
Good luck with your family and your car. Hope you can get back to normal soon.
Old Sep 17, 2005 | 09:46 PM
LOTAHP's Avatar
LOTAHP
Old Sep 17, 2005 | 10:31 PM
hubes's Avatar
hubes
Originally Posted by 7t2vette
your vette is gorgeous, I hope you can save her.
I am glad you and your family are okay.
except that guy holding the sign shouldnt be smiling, he should be
Old Sep 17, 2005 | 10:42 PM
Todd68's Avatar
Todd68
Sorry to hear that. Your car was always one of my favorites on CF too. Glad to hear your family is safe.
Old Sep 17, 2005 | 10:58 PM
Bangkok Dean's Avatar
Bangkok Dean
With all that has happened to you and your family you seam to have your priorities in order.There are mant tasks in your future but some day you will look back and say "glad that is behind us"
"Everything is okay in the end. If it's not okay, then it's not the end."
Old Sep 18, 2005 | 01:13 AM
ffas23's Avatar
ffas23
Originally Posted by crf311
Well if's official. Hurricane Katrine got my vette with about 3 ft of water. I'll try to post some pics later. It looks like a mess. I have more things to worry about before I decide what to do with it, Like fine a place to live. Oh well at least all my family is safe. Just wanted to kill some time here. Good luck everyone. robert
Robert glad to see your family is safe and sorry about your loss. Question for you. Did you do anything with your car as of yet? The reason for me asking is because my first Corvette a 67'Vert went under water in a flood back in 71' caused by Tropical Storm Doria. A few days after the flood waters went down I jacked the front end up and drained the oil pan first letting out all the water. The water will come out first and then eventually the oil which will float on top of the water. I actually held a drain pan under the oil pan and moved it to the side when just water was coming out until I saw the oil starting to come out. After this I took all spark plugs out and removed the oil filter. I then hit the starter with the coil wired removed to spin the motor real quick and all water shot out of the cylinders. I then reinstalled all spark plugs, installed a new oil filter and put new oil in. In my case no water got into the gas tank so I started the car up and let it run for 10-15 minutes to heat the engine up changing the oil again after a week or so of running it. Later on after attending to my parents home I started taking the interior apart and what have you out of the car until I had bare floors. This was the only car I had at the time so I would drive the car using a plastic milk case as a seat believe it or not locally back then. Later on I took it to a shop I knew in another town unhit by the flood waters and they drilled and tapped the bottom of the M21 4spd trans and let all water and gear oil out and then installed a plug and refilled it. I purchased a suction gun for the rear end to get any water and gear oil out and refilled it. Believe it or not the flood water had no affect on the engine, trans or rear. The 327-300 engine never burned a drop of oil either. I am sure you can save your car if you spend a little time with it. The flood water shouldn't of affected your body and paint unless something rammed into it. If you can save your motor,trans and rear you are half way there and can take your time with everything else. Good luck. Fill us in with what you do if you have the time.
One good thing your C-3 like my C-2 at the time doesn't have all the computer baloney that the newer cars have so getting them going is alot easier. If I had a C-4 to C-6 go underwater I would just let the insurance adjuster take it away.
Fred
Old Sep 18, 2005 | 01:35 AM
LiveandLetDrive's Avatar
LiveandLetDrive
Ever seen the British show Top Gear and the pickup truck they tried (very, very hard) to kill and never could? Old cars are like that and if you have the money and time I'm sure you can bring her back. Good luck and glad you're safe.
-Chris
Old Sep 18, 2005 | 06:56 AM
groovyjay's Avatar
groovyjay
Originally Posted by zwede
That was one of my favorite cars on the forum.
Old Sep 18, 2005 | 07:14 AM
73jst4fun's Avatar
73jst4fun
Glad to hear you and your family survived and your safe, it's a shame about your home and vette. Most of us have never come close to have a major disaster like that affect us.....good luck and keep us posted....
Old Sep 18, 2005 | 07:49 AM
Glenn"Mr.Blue"Smith's Avatar
Glenn"Mr.Blue"Smith
From: Edgewater (20 miles south of Daytona) Florida
My wife and I have heavy hearts for what you have been through. God will give you the strength to carry on when all else seems to let you down. Insurance will take care of the other stuff, or good natured people like those here on the forum.
Have faith, the rest will come.
If you need something, including a place to stay, let us know and we will help you within our meager means. Seriously!
Glenn & Kathy Smith
Old Sep 18, 2005 | 06:34 PM
guppie's Avatar
guppie
St. Jude Donor '08
Sorry to hear you had to go through such a thing, good luck in getting your life back in order
Old Sep 18, 2005 | 06:36 PM
  #33
Corey_68's Avatar
Corey_68
Damn that sucks man, sorry to hear that.
Old Sep 18, 2005 | 11:14 PM
  #34
Z-man's Avatar
Z-man
Oh no - I really liked your car!! Hopefully, you can get your family and everything else in your life straightened out OK.
Maybe you can get the Vette fixed the way ffas23 described...
