speedo cable troubles
Old Sep 27, 2005 | 12:56 PM
cab's Avatar
cab
Default speedo cable troubles
what is the proper name for the box the upper speedo cable goes into on a 77 w/cruise. i keep twisting my lower cable off at the trans. just thought something maybe bad in that conrol box.
Old Sep 27, 2005 | 01:34 PM
Star79's Avatar
Star79
transducer. you can remove it and check the guts to see if anything (gears, spring etc) is messed up. More likely your lower cable is binding inside somewhere, unless you've already replaced it that is.
