No it won't make 390 hp. The rating was SAE gross which meant no accessories, headers, tweaked carb & ignition etc. It was also at the flywheel. In '71 the vette was rated both SAE gross and NET. NET means with accessories, production carb, exhaust (including mufflers) and still at the flywheel. 71 was 365 hp gross, 285 NET. I put my 71 on a chassis dyno when it was almost stock. Only non-stock item was a replacement cam with about 5 degrees more duration (maybe 10 hp). It made 255 hp at the wheels.
I kinda figured that, just stepping on the gas it never felt like 390, kinda dissapointing, so I guess to make it 390 you would have to do a lot like new cam, piston, full exhaust and carb. Mabe then do you think it could make the 390?
I bet you could do a lot with cam, heads and exhaust. That way you wouldn't have to pull the engine. Somebody should chime in here with more specifics.
Zwede - Was there a higher HP 454 in 71 or 72? Many years ago I had a friend come over and we installed new brake lines in his 454. I can't be 100% sure, but I think that it was stock other than a doug Nash 5 speed. Compared to my L-82 350 ci it was a rocket ship.
It was probably the big block TQ that was impressing me.
The LS-5 responds extrememly well to mods. Headers, small cam, single plane intake and 750 Holley got me about 400 flywheel hp (328 rwhp) vs the stock 285. Mild aluminum heads and a mild hydraulic roller cam bumped it to about 490 (392 rwhp). This is still a very mild combo setup for daily commuting. You can get 450 rwhp (over 550 at the flywheel) with good heads such as AFR 305 or Brodix race-rites and a bigger cam. It would still be very driveable. All without ever taking the short block out of the car.
Even stock they scoot fairly well. Make sure something isn't holding it back. Retarded ignition timing really kills power as well as a plugged fuel filter. Also verify that pedal to the floor really opens the throttle all the way.
A stock LS-5 runs a 14-flat @100+ mph, 0-60 in 6 secs.
The 70 was rated higher at 390 gross. Sure you knew that, but just wanted to clarify for others.
Well I will have to try some of thoes simple mods to see what I get for HP, I will probably put it on a dyno to get a base line and go from there. I am real curious about what it is at right now.
Has anyone ever put a stock 1970 vette with a 454 BB on the dyno and got the 390 HP out of it like it says it should?
I did something of interest. In 1987 when I bought my first (of seven) Corvettes, a 1970 LS-5 coupe, I bought a CRR coded 1970 Chevelle LS-6 engine and completely had it rebuilt to STOCK specifications, using all NOS GM correct factory parts. Cost was $4,117.00 back then. Had it on an engine dyno, results were 493hp in pure stock configuration.
