need more gauges
Old Oct 14, 2005 | 05:33 PM
onaqwst's Avatar
onaqwst
Default need more gauges
so, i'm going to remake my center console and shifter plate setup again and gonna make it a one piece morph design..... i have 6 gauges...speedo/tach/volt/water temp/oil pressure/fuel..... any more i should add...... like trans temp/oil temp/fuel air..etc....
b
Old Oct 14, 2005 | 08:13 PM
PhotoVette1's Avatar
PhotoVette1
I always thought a engine coolant pressure gauge would be nice--detect the overheating problem before it happens.
Old Oct 14, 2005 | 08:23 PM
zwede's Avatar
zwede
Air/fuel ratio (wideband) and fuel pressure is useful.
Old Oct 14, 2005 | 09:39 PM
84rzv500r's Avatar
84rzv500r
Lets see...
I have a tach, speedo, water temp, oil press, oil temp, fuel press, fuel qty, volts
I'm gonna add trans temp, diff temp and PS temp, and vac, and a laptop just so I can take some more crap from the local hot rodders
Old Oct 14, 2005 | 10:44 PM
WhichVette?'s Avatar
WhichVette?
Altimeter
Old Oct 14, 2005 | 11:30 PM
DMONSVETTE's Avatar
DMONSVETTE
Originally Posted by WhichVette?
Altimeter
Old Oct 15, 2005 | 01:12 AM
strokervette's Avatar
strokervette
I want to make a custom console with fuel, volt, oil pressure, coolant temp, and vaccum. Lets see some pics so I can get an idea of how to make mine.
Old Oct 15, 2005 | 01:54 AM
Scottys78's Avatar
Scottys78
MPG gauge
Old Oct 15, 2005 | 04:56 AM
Twin_Turbo's Avatar
Twin_Turbo
I have tach, speedo, volts, boost/vac, cyl head temp, water temp, water pressure, oil press, oil temp, fuel press, fuel level, trans temp, diff temp, pyro. I will probably add an A/F one also.
Old Oct 15, 2005 | 08:50 AM
WhichVette?
Blood Alcohol Content
Old Oct 17, 2005 | 02:18 PM
onaqwst's Avatar
onaqwst
i was thinking about a broken gauge....... since everything else seems to not work right all the time mine as well....... and possibly a volumn gauge and an age gauge..........ha
Old Oct 17, 2005 | 03:25 PM
ltlevil's Avatar
ltlevil
I'm in the same boat, pretty much decided either a trans temp or fuel pressure gauge is the way I'm going. Fuel pressure would be nice to know when I hit the "GO2" button! On the other hand trans temp is good to know all the time, especially with a 4500 stall!
ltlevil
To need more gauges
