70 Wheel codes
Old Oct 25, 2005 | 07:57 AM
sarchevyman's Avatar
sarchevyman
Default 70 Wheel codes
Hello, I am trying to located a set of OEM wheels for my 70 vette. Could someone educate me on the correct wheel code for this year? Thank you in advance for the help, Steve
Old Oct 25, 2005 | 05:15 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
Not real positive about this but I think 69-up wheel codes are "AZ"
Old Oct 25, 2005 | 05:31 PM
694speed350's Avatar
694speed350
Default 70 wheel code
on the ralley wheels the code is stamped around the valve stem as per example. k- kelsey hayes,followed by a dash and 1 which means cheverolet,next comes another dash followed by a 0 to tell the year(70) followed by a space and 1 or 2 numbers to indicate the month. on the other side of the valve stem hole 1 or 2 numbers that are the day of the month. az is the correct letters for the period. hopes this helps awa
To 70 Wheel codes
