Just snapped a half-shaft
Old Oct 29, 2005 | 12:24 PM
ICEMAN59's Avatar
ICEMAN59
Default Just snapped a half-shaft
Laid on it hard and the drivers side half-shaft broke at the wheel, can't push the car think I messed up the rear end. At least it was in the driveway. We did some tuning and I wanted to test it. Oh well
Old Oct 29, 2005 | 01:53 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
are the half-shafts aluminum or steel on an 80?
Old Oct 29, 2005 | 02:20 PM
zwede's Avatar
zwede
You sure it was the half shaft and not just a U-joint?
Old Oct 29, 2005 | 02:22 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
That sux!! Hopefully it will be just a u-joint only.
Old Oct 29, 2005 | 03:08 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
It would be wise to get some safety loops from DRAGVETTE
So next time there really won't be no damage, If Im correct, you have a well built motor in there
Old Oct 29, 2005 | 03:38 PM
ICEMAN59's Avatar
ICEMAN59
steel
Old Oct 29, 2005 | 03:39 PM
ICEMAN59's Avatar
ICEMAN59
It broke at the u joint but it messed the shaft up.
Old Oct 29, 2005 | 03:41 PM
ICEMAN59's Avatar
ICEMAN59
Yea it's from the engine factory around 480hp we were having problems with the vacuum advance and got it straight. Too much for the u-joints!
Old Oct 29, 2005 | 04:40 PM
Twin_Turbo's Avatar
Twin_Turbo
You're lucky if it's the halfshaft and not the diff itself
To Just snapped a half-shaft
