Door Panels
Old Nov 4, 2005 | 08:01 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Default Door Panels
I just got my new door panels for the 77, I am going to change the trim over and was looking for any comments or tips on this. As most of you know most of the trim swap is straightforward. But what about the door handle trim parts with the rivets?
Grind them off drill and reinstall with self-tapping screws and a washer?
Thanks Steve
Old Nov 5, 2005 | 04:45 AM
Greenwood79's Avatar
Greenwood79
Not sure this will help..I have a '79 and this reply was posted for me a few days ago.
Andy (Greenwood79)
Lower edge of carpet is sewn to vynal...vynal is wrapped under the bottom of panel and stapled to door panel on the back side. Top edge of carpet is held on by chrome strip. Don't know what others have done about replacing JUST the carpet...I actually sewed mine back onto the old vynal then re-stapled...but carpet with vynal already attached is available through catalog vendors.
Eddie
Old Nov 7, 2005 | 11:58 AM
68/70Vette's Avatar
68/70Vette
Thanks Steve
Yes. (This is the door handle bezel that the door handle itself mounts into and also the round lock/unlock) If you buy this trim piece new, it comes with little self-tapping screws and washers.
Old Nov 7, 2005 | 04:31 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Old Nov 8, 2005 | 12:12 AM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
Just in case you want to do something easier, you can pop off the soldered-on washers on the back side of the door handle trim and simply use J-B Weld to hold the piece onto your new panel. I did it and it worked terrifically. I figured that if I ever got new door panels AGAIN, I'd buy the new trim pieces anyway, so future removal was not a question.
To Door Panels
