69 rear bumper question?
Old Nov 14, 2005 | 09:39 AM
Surfer69's Avatar
Surfer69
Default 69 rear bumper question?
Can someone check and see if the rear bumpers are slanted to one another or straight across? I recently got the rear end fixed and dont remember my bumpers being angled at the rear edge with the outer side sections slightly more forward. I thought both rear edges run straight to each other.
Old Nov 14, 2005 | 09:45 AM
sly vette's Avatar
sly vette
Mine seem to be straight
Old Nov 14, 2005 | 09:47 AM
big_G's Avatar
big_G
Square and straight. Specs. are in the assembly manual, If you need them.
Old Nov 14, 2005 | 02:39 PM
68/70Vette's Avatar
68/70Vette
They probably just need to be aligned better. They should be straight. If you got your rear end recently "fixed," a bracket or two may be bent. You can still buy all the brackets new. For instance Volunteer Vette is a forum sponsor.
I was surprised how much time it took be to align my rear bumpers (and front bumpers). I probably took two hours to get the rear bumpers and rear exhaust valance panel on correctly. Could do it a lot faster now, but there was a learning curve process.
Old Nov 14, 2005 | 04:12 PM
Surfer69's Avatar
Surfer69
I'm sorry to say, but I think you guys are all wrong or I didnt describe the situation correctly.
I went to the shop at lunch and looked at 5 or 6 68-72 cars with rear chrome bumpers and all had a slight angle to the bumpers.
Now let me make sure you know what I'm saying. If you were above the car looking down at the rear bumpers, and you tried to lay a staight edge across the most rear edge, both bumpers would not be nice and flat against the straight edge, but would touch the straight edge in the center of the car and taper slightly forward by about 3-5 degrees.
Old Nov 14, 2005 | 10:04 PM
GUSTO14's Avatar
GUSTO14
...Now let me make sure you know what I'm saying. If you were above the car looking down at the rear bumpers, and you tried to lay a staight edge across the most rear edge, both bumpers would not be nice and flat against the straight edge, but would touch the straight edge in the center of the car and taper slightly forward by about 3-5 degrees.
They should follow the contour of the body with pretty much even spacing along the way. You might want to try posting a picture if possible.
GUSTO
Old Nov 15, 2005 | 09:21 PM
C3 Stroker's Avatar
C3 Stroker
My bumpers are in their original location and they appear to be very, very slightly angled in toward each other......you be the judge....
Old Nov 15, 2005 | 09:25 PM
ksbunting's Avatar
ksbunting
I have owned my 68 since 1972 and my passenger side rear bumper also seems to have the slightest pitch up at the corner where it makes the 90 degree bend toward the front of the car by the side marker light.
I have checked everything and can't seem to correct it. Guess I'm not alone. Most people might not notice it but I do. The driver side is straight (horizontal).
Kurt
Old Nov 15, 2005 | 10:12 PM
Daytona69's Avatar
Daytona69
Here's my '69...looks like there is a slight pitch.
Old Nov 17, 2005 | 09:21 AM
Surfer69's Avatar
Surfer69
You guys still dont get it. I said looking down from ABOVE the car. Not looking forward at the rear edge.
To 69 rear bumper question?
