BS or True
Old Dec 15, 2005 | 08:57 PM
67L36Driver's Avatar
67L36Driver
Default BS or True
http://www.autofacts.ca/classics/FAPC/ZL1Corvette.htm
Riddled with misinformation or mostly correct?
You guys & girls most likely see this once a week. (Sorry)
Old Dec 15, 2005 | 10:06 PM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
From what I've read it seems mostly right...except the 200 mph with stock gearing and running 11's at the same time. I believe with these cars it was either one or the other, not both. Remember, these only had 4 speeds, not 6 speeds like today. The top speed of today's C6 Z06 is 195, and that's with 6 speeds, and a very aerodynamic car comparatively. I don't remember the C3 being know for its fantastic aerodynamics. I'd be nervous as all get out at over 150 MPH.
trw
I had an autoweek article that talked about the ZL1.
Here it is.
http://www.autoweek.com/article.cms?articleId=7427
Old Dec 16, 2005 | 12:32 AM
Ironcross's Avatar
Ironcross
Basically correct. However both the L88 and ZL1 were identical in every respect except for the block. GM`s horsepower rating was 430 and not 435. While low 11`s were frequent at 120+, a 10.5 at a 132 mph trap speed is suspect for a factory "stock" Vette naturally even with slicks. Those extra 10`ths are easy to come by over a bench but hard to come by in reality on the track.
Old Dec 16, 2005 | 08:42 AM
mongo6901's Avatar
mongo6901
trw
Here it is.
I don't believe the number of speeds in a transmission has anything to do with top speed. That is completely dependent on your final gear ratios.
And I agree with you on being nervous. I get nervous just approaching 100 let alone 150.
Old Dec 16, 2005 | 08:44 AM
harrin's Avatar
harrin
Old Dec 16, 2005 | 11:49 AM
rihwoods's Avatar
rihwoods
At 100,I find the C3 stable...at 110 plus,steering gets "light" due to lift at front end...(air getting under front end)...
Old Dec 17, 2005 | 09:06 AM
Ganey's Avatar
Ganey
Yes, basically right both articles. Duntov on the ZL-1 Corvette several built & "2 escaped" i.e. sold. The L-88 made the most power though both were underrated at 430 so that the unknowledgeable who would just buy the engine w/ the most hp would go for the 435 HP engine.
Old Dec 17, 2005 | 11:17 AM
rcread's Avatar
rcread
I've seen that white ZL1 locally, at a car show. If you look closely, you can still see some of my drool on the windshield.
To BS or True
