engine codes
Old Dec 22, 2005 | 08:21 PM
harrin's Avatar
harrin
Default engine codes
on a 71 corvette the casting numbers is 3963512,the code should be CPH,where do I find this code is it stamped or is it forged? Any help is appreciated
Old Dec 22, 2005 | 09:29 PM
LYLE's Avatar
LYLE
The CPH is on the stamp pad on the RH front of the block where the head is bolted on. Should have a T XXXX date month XX day XX then CPH. Then the vin derivative the last numbers should be your VIN if the block is original.
Old Dec 23, 2005 | 10:58 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
CPH would be correct for a 365hp/454 4sp
To engine codes
