Coolant Temp Gauge
Old Dec 23, 2005 | 07:24 PM
TPI BOY's Avatar
TPI BOY
Default Coolant Temp Gauge
Can you tell me on the back of the water
temp gauge on what screws the electrial prongs
go on and does any of the prongs need an insolator.
it's a 1975
Old Dec 23, 2005 | 10:04 PM
TPI BOY's Avatar
TPI BOY
Can someone please help
I would like to see the gauge work
Old Dec 23, 2005 | 10:43 PM
TPI BOY's Avatar
TPI BOY
ttt
Old Dec 23, 2005 | 11:11 PM
vetteboy1976kr's Avatar
vetteboy1976kr
I guess the question is a little hard to understand. Are you asking which wires go where?
Old Dec 24, 2005 | 08:55 AM
A72COUPEDT's Avatar
A72COUPEDT
Default Wires go where??
Since my car(a 72) is apart, I just went out to look for ya.
NO luck, mine has a connector(plug in type)
Sorry...anyway you'll go back to the top of the page now and 75'er can chime in here...lets hope!
Good luck! Dave
Old Dec 24, 2005 | 10:27 AM
TPI BOY's Avatar
TPI BOY
Yes I have the connector, what I need
to know is where the long metal prongs
go on the gauge, what the connector
plugs in to
and does any of them
have a isolator washer on them
Old Dec 24, 2005 | 12:02 PM
vetteboy1976kr
TPI,
Take a look at the gage cluster in this ebay auction:
http://cgi.ebay.com/ebaymotors/Corve...QQcmdZViewItem
It is a good example of what an original gage set up should look like. You can also enlarge the pics to show the insulators that go between the screw terminals and the gages. If your insulators are shot, use some small rubber washers instead. Hope this helps.
Old Dec 24, 2005 | 12:39 PM
TPI BOY's Avatar
TPI BOY
To Coolant Temp Gauge
