Half shafts
Old Dec 28, 2005 | 10:09 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
Default Half shafts
What is it about the Half Shafts that you would need to replace them rather than just replacing the U-joints?
Old Dec 28, 2005 | 10:30 PM
shafrs3's Avatar
shafrs3
If they're bent or twisted, or if bubba beat out the old joints and bent a yoke ear.
Old Dec 28, 2005 | 10:34 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Check out the February 2006 Car Craft magazine. In there they have a picture of a corvette half shaft that was twisted in half by mostly stock small block at the dragstrip. The guy is a forum member but I cannot remember his forum name. He has a red 80 and his real name is Stephen Barthe according to the article in Car Craft.
Old Jan 5, 2006 | 06:14 PM
American Boy's Avatar
American Boy
Hi,
Well, stock half-shaft will hold if you run street tire. I ran 400 hp with solid spicer U-joint without problem for 3 years. Any engine with slicks and manual trans will twist them. In my case, the excellent track preparation(really sticky), the slicks and my LS7 clutch pressure plate did the work.
Stephan
Old Jan 5, 2006 | 06:18 PM
Gordonm's Avatar
Gordonm
Maybe I'm going to need new half shafts. I'm putting in a stroker and it will see some drag strip time. 500+ HP will probably do them in, the track is sometimes pretty prepped and sticky.
Old Jan 5, 2006 | 07:46 PM
carl a's Avatar
carl a
i just put 1/2 shaft safety loops under the 73 because i knew the engine was gonna get up there in the ponies and i dont like it when my 1/2 shafts looks like this----------------------------------------------------------------------------
Old Jan 5, 2006 | 08:08 PM
Z-man's Avatar
Z-man
When I get the money, I'll be putting in some Titanium half shafts...
Old Jan 6, 2006 | 11:03 AM
carl a's Avatar
carl a
is there such a thing? are they real shiney??
To Half shafts
