Removing swirls
Old Jan 10, 2006 | 11:27 AM
kona's Avatar
kona
Default Removing swirls
Okay it's time to start thinking about spring so naturally I want get the car looking really good. My car is Torch Red and the paint job is about a 7.5.
The problem that I have is that I have the infamous swirl marks that are really noticeable in the sunshine. What do you do to remove them and what did I do to cause them?
Kona
Old Jan 10, 2006 | 11:56 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Kona
The cause is likely a carwash or something you used to polish, wax, or dry the car.
Assuming they're light scratches in the clearcoat they can usually be polished away. A random orbit polisher/sander with the appropriate polish and pads can help with the job a LOT. Griots is more than a little expensive for the polisher, but their hook & loop pad system and polishes and waxes are a great combo:
http://www.griotsgarage.com/catalog.jsp?&SKU=10625
Old Jan 10, 2006 | 11:58 AM
wnmech's Avatar
wnmech
3M puts out whats called swirl remover. It runs around $12 for about a 16oz plastic bottle. I have used it to remove swirl marks in my Camaro it works real good
Old Jan 10, 2006 | 12:43 PM
isosceles's Avatar
isosceles
Turtlewax also has some colored wax.....Red, Blue, Black, White, etc that actually has paint in the wax. The paint fills in the swirl marks. I've used it on a black car, works great! Use gloves when you apply it. The stuff really stays under fingernails.
Old Jan 10, 2006 | 01:36 PM
6t9427's Avatar
6t9427
This stuff worked great on my 69.
Old Jan 10, 2006 | 02:21 PM
70vert's Avatar
70vert
Banned Scam/Spammer
You could use Zanio if you want a non-abrasive method.
Old Jan 10, 2006 | 02:29 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
That red TurtleWax works great
And yes, do yourself a favor and wear gloves when you use it
Old Jan 10, 2006 | 03:01 PM
427basketcase's Avatar
427basketcase
I had them real bad in my big black car, Until I was turned on to Adams Polishes The stuff works!
Old Jan 10, 2006 | 03:24 PM
kona's Avatar
kona
Found the Turtle Wax Red O"Reillys carrys it will give it a try thanks for all the help.
Kona
Old Jan 10, 2006 | 03:56 PM
Jims79's Avatar
Jims79
Kona
Kona, DON'T use the turtle wax. I used everything and the best for paint is Maguires. They have a #9 for removing swirls and a # 7 for a deep polish then a # 6 yellow wax for protection. Each bottle cost about $9 and you can get 3 applications from them.
For chrome and aluminum I use mothers.
Old Jan 10, 2006 | 04:07 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Swirl remover just hides them( I have many high quality used car waxes that shine better than anything and show no swirls until you wash it ) .
Your going to want to polish them out to actually remove them. Then you will wnat to do a hand glaze for a better shine. Then follow it up with a good wax. We did this on all of our cars and none have swirls even my dads black truck.
We used mothers professional series for the polish and hand glaze and mothers paste wax.Liquid or paste is just preference.
Also make sure to stick witht he same brand or the shine will be somewhat dull becuase the companys chemical compounds react with each other.
Old Jan 10, 2006 | 04:11 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I don't really like zanio. It just an overpriced wax.
Old Jan 10, 2006 | 04:22 PM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
Read and follow directions,very easy to use.....great shine!
Old Jan 10, 2006 | 06:52 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Here's another vote for Adam's. Use the link above and go to their web site. There are videos you can download that will show the whole process of getting your car to look new again.
Old Jan 10, 2006 | 10:08 PM
Glassbowtie77's Avatar
Glassbowtie77
Old Jan 10, 2006 | 10:18 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
........the best for paint is Maguires. They have a #9 for removing swirls and a # 7 for a deep polish then a # 26 yellow wax for protection. Each bottle cost about $9 and you can get 3 applications from them.
i agree this stuff is the best its all i use....
Old Jan 10, 2006 | 10:21 PM
71rdster's Avatar
71rdster
Maguiars is the way to go. My .02
Orville
To Removing swirls
Old Jan 10, 2006 | 10:31 PM
big_G's Avatar
big_G
Swirls are hard to prevent and even harder to remove. Even your hands can scratch a clean surface. Dry cloth towels can scratch, as can wash mits that are not really clean. I have separate mits for the body and tires/dirty body areas. Use a damp chamios to dry the surface. Swirls are an inevitable side-effect of washing your Vette. The less you wash it, the less swirls. Lots of wax can't hurt either. Most swirl removers merely fill the micro-scratches...that's ok, the look is good!
Old Jan 10, 2006 | 10:36 PM
Edzred72's Avatar
Edzred72
To remove swirl marks from the clearcoat, and to take out fine scratches from the clearcoat, 3-M Hand Glaze will make that clearcoat surface like new again.
Eddie
Old Jan 10, 2006 | 11:01 PM
stepinup's Avatar
stepinup
Kona,your swirls are scratches from washing,drying,touching,ect...they only way to really get rid of them is to cut and buff.this should be done by a pro if you havnt done it before.what they do is replace your swirls(scratches) with smaller sctraches by wetsanding with 1000 to 2500 grit ect.,then they go through diff.stages of buffing using diff.pads,first wool then foam and then a finish pad,when done right even a black car will have no swirls and wont reappear for a long time if you are carefull.different componds will fill the scratches without taking them out,they are just a temporay fix and the swirls will come back sooner,you will have to keep applying and applying.3m hand glaze is one of them.I use system 1 as you can use it through the whole process where diff. manafactures have you use several compounds through the cut and buff process.once your car is cut and buffed right ,only wash and dry with micro fiber towels , when washing use lots of water and dont push hard,Hint;when washing and drying,dont move in a circular motion,but a stright motion ,this will helpthe swirl problem,Darryl
