Rear Gear Ratio Decipher?
Old Jan 26, 2006 | 08:57 AM
Hvymtlc5's Avatar
Hvymtlc5
Default Rear Gear Ratio Decipher?
While I had the car jacked up doing calipers last night I decided to try and figure out my gear ratio is in my 78......the drive shaft turns one full turn to the tires 3/4 turn...not good at math concepts....approximately what ratio do I have?
3.34??
Old Jan 26, 2006 | 09:09 AM
big_G's Avatar
big_G
That can't be right. Re-check it. Minimum you should see is 3 turns of the driveshaft to 1 turn of the wheels....(3.08 in this case)...
Old Jan 26, 2006 | 09:24 AM
GDaina's Avatar
GDaina
use chalk, mark the differential and the yoke, also mark the tire at either 12 or 6 o'clock then rotate the tire and count how many times the chalk mark passed the mark on the diff for one rotation of the tire. Don't try to eyball the rotations, use chalk.
Old Jan 26, 2006 | 09:30 AM
evalu8r's Avatar
evalu8r
Mark the wheel and ujoint. You should get a minimum 3 turns of the joint to 1 turn of the wheel. Less than 3 and it is a good highway cruiser and lousy at the light. I think most were 3.55 or 3.73.
Chris
Old Jan 26, 2006 | 10:01 AM
Hvymtlc5's Avatar
Hvymtlc5
I was sure I kept an eye on the driveshaft revolutions...must have been the brake fluid and cigar fumes...and missed a few turns. I check it again tonight.
Old Jan 26, 2006 | 10:29 AM
mooneyd's Avatar
mooneyd
What you said would give you a 1.33 rear, so you need to redo it. Use the method stated above.
Old Jan 27, 2006 | 08:00 AM
Hvymtlc5's Avatar
Hvymtlc5
OK guys, Put the tranny in neutral, crawled under the Vette again. Chalked the drive shaft (not the half shaft) and put a chalk mark on the tire. The drive shaft rotates 1 turn to the tires 3/4 turn. Doesn't make since to me ..what the heck kind of ratio would that be??? I know it doesn't sound right..............
Old Jan 27, 2006 | 08:14 AM
Gordonm's Avatar
Gordonm
That is impossible unless your rear end is really bad. Did you watch the other tire also. Are they both spinning the same way. They should be both spinning the same way with a posi rear end. Sounds like something might be wrong. My drive shaft spins 3 3/4 turns for every wheel rev. Hence a 3.70 rear.
Old Jan 27, 2006 | 09:00 AM
Hvymtlc5's Avatar
Hvymtlc5
What's the highest ring and pinion combination that could go in a 78 carrier? Right now with those rotations, I'm looking at an impossible 1.33 ????
Just don't undestand what's going on.........
Old Jan 27, 2006 | 09:18 AM
stingr69's Avatar
stingr69
First - Rotate the drivetrain until the WHEEL goes 1 full rotation while counting the driveshaft rotations. Not the other way around.
Both tires need to be off the ground and rotating together. You will see something like 3 full driveshaft rotations for 1 full wheels rotation.
You probably have about a 3.08:1 ratio (~3:1 ratio) in that differential so 3 driveshaft rotations will give you 1 wheel rotation.
-Mark.
Old Jan 28, 2006 | 12:26 AM
jerrylee's Avatar
jerrylee
Default ratio..
if u have an auto..the stock gears should b 3.08 0n the L-48 n 3.55 0n the L-82.......
Old Jan 28, 2006 | 03:10 PM
Hvymtlc5's Avatar
Hvymtlc5
Back up under the car again..absolutly positive that the drive shaft turned two solid turns to the wheels 1 1/4 revolution. What gear ratio (or lack of) would this be?
Old Jan 28, 2006 | 05:02 PM
GDaina's Avatar
GDaina
Tell you what you do....make another mark on the diff and line the driveshaft mark with the diff...then place a mark on the inside tire at 6 o'clock and slowly rotate the tire and count the number of times the drive shaft mark passes the diff and stop when the tire is on the 6 o'clock position
Whatever you are doing, you are not doing it properly
Old Jan 28, 2006 | 06:01 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Look at the code on your rear end.
OK - 3.08
OM - 3.36
OH - 3.55
OJ - 3.70
Old Jan 28, 2006 | 09:33 PM
Hvymtlc5's Avatar
Hvymtlc5
I know what I'm seeing - baffles me too - that's why I'm posting Is there a possibility that someone had a very high ratio rear end installed back in the 70's?? With those rotations (2 driveshaft to 1 1/4 tire rotation) it would be extremely high.
For sanity, I will check it once more in the a.m.
Old Jan 29, 2006 | 02:01 PM
stingr69's Avatar
stingr69
One more thing to look at...Make sure that both wheels are rotating the same direction. This will happen if you have a limited slip differential. If one wheel rotates forward and one rotates backwards you do not have a limited slip differential. That could be a problem with this procedure.
-Mark.
Old Jan 30, 2006 | 08:50 AM
Hvymtlc5's Avatar
Hvymtlc5
Didn't all Vettes have a limited slip? Anyway, both wheels turn the same direction.. and the 1 1/4 wheel rotation to two driveshaft rotations still stands......
Any other ideas?
To Rear Gear Ratio Decipher?
