Seat Tracks
Old Jan 29, 2006 | 02:17 PM
StevenF's Avatar
StevenF
Cruising
Default Seat Tracks
Anyone know how to take apart the seat tracks? I removed the seat yesterday, and would like to bead blast and clean the tracks. Also the front mounts are broken off so will need to be replaced. Any advice is appreciated. I fiddled with it some yesterday, but couldnt figure out how to seperate the 2 pieces.
Old Jan 29, 2006 | 02:30 PM
StevenF's Avatar
StevenF
Cruising
Thanks for the advice, but I do need to take them apart. I need to get access to remove/replace the front mounting brackets.
Old Jan 29, 2006 | 03:33 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
The front mounting bracket can be replaced without disassembly of the track. I think you will loose the ball bearings if you disassemble.
Old Jan 29, 2006 | 03:53 PM
StevenF's Avatar
StevenF
Cruising
Okay, well heading out and gonna pick up vinegar and then soak em. Hope all works well, will have to search parts catalog to get the front brackets, doubt they're very common. Thanks for the advice from both of you!
Old Jan 29, 2006 | 05:23 PM
StevenF's Avatar
StevenF
Cruising
Awesome thanks ed. I've got em soaking in vinegar as you said, hopefully it works out great. Always quick answers on this forum!
To Seat Tracks
