Having C3 Troubles...
Old Jan 29, 2006 | 10:40 PM
C3VetteMan's Avatar
C3VetteMan
Cruising
Default Looking to buy a C3...
Hey everyone, I've been a fan of C3's forever, but never got too serious about buying one until now due to work, school, etc. I'm currently debating between a 76 and a 77, but I'm not too sure which one I prefer. I really like the way the 76's look, but with the 77 I'm not sure what paint scheme I'd go with. My main questions in buying either model year is mainly concerning the overall look of the car as well as the interior. My main concern without a doubt is the motor, I'm a big fan of horsepower and wanted to know if there was an advantage of one over the other.
Thanks a ton guys,
Eddie
Old Jan 29, 2006 | 11:01 PM
lowbuck72's Avatar
lowbuck72
First check your emmisions laws. Is a 76 or 77 smog exempt in your state? Here in CA a '74 or older is smog exempt. If you have to worry about smog checks or yearly inspections, consider going with an older model. Otherwise, you will pretty much have to leave the engine fairly stock, with all emmisions equipment on and functioning.
Old Jan 29, 2006 | 11:08 PM
TonySinclair's Avatar
TonySinclair
'75 and older in CA.
Old Jan 29, 2006 | 11:15 PM
C3VetteMan's Avatar
C3VetteMan
Cruising
Luckily enough, my area is free of the smog tests so I can stick with my dream car in a 76 or a 77. Thank you so much for asking that though, because I hadn't checked that till now.
I'm really just having trouble deciding between a 76 or a 77. Also, ever now and then the thought of buying a 75 or lower C3 lingers into my mind, but I still haven't been sold on one car specifically. I'd really like to get some opinions on what years have the best motor, interior options, body style, etc. That's kind of why I posted in the 'Tech Section', because I wanted to get an idea of C3 years have the best specifications.
Old Jan 30, 2006 | 12:13 AM
C3VetteMan's Avatar
C3VetteMan
Cruising
Are the 76 and 77 models identical to each other?
Old Jan 30, 2006 | 12:38 AM
tracdogg2's Avatar
tracdogg2
It depends where the dome light is on the 76. If it's in the back it looks like a 75. If it's between the t-tops it looks more like a 77. Except for the steering wheel. 76 only.
Mike
Old Jan 30, 2006 | 01:42 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The center gauge cluster and console is the same as the 78-82 models. The rest of the interior (except for the aforementioned 76.2-82 dome light location is the same design as the earlier models. The body is identical to a '76, but the emblems are different.
Old Jan 30, 2006 | 08:13 AM
Ganey's Avatar
Ganey
Did you go look at them? Not identical, 74-77 are very similiar. Note mirrors, door panel inserts & console.
The 77 has a shorter st. column, a plus if tall. Some 77 info. on my website.
Old Jan 30, 2006 | 09:02 AM
72on18s's Avatar
72on18s
I had a '77 initially - lovely shape, and as has been said - identical to the '76 body wise. Interior is different; console mainly. As for performance, nothing really to choose between them. If you aren't concerned with factory originality then there is no power advantage that can't be easily, and cheaply, matched.
Main thing as far as I would be concerned, and it's a minor point, but '76 is the last year the Stingray name was used. So a '77 won't have the Stingray badge. Here in England, people see a C3 and assume it's a Stingray. With the '77 I used to say "well, you're sort of right, but it's not actually a Stingray" . With my '72 I just say "Yes, it is a Stingray" - much easier
Just get the best '76 or '77 you can. Colour, condition etc is, IMO, more important.
Old Jan 30, 2006 | 09:12 AM
Ganey's Avatar
Ganey
Actually, 68-77 Stingray see:
http://ganeys.home.sprynet.com/STINGRAY.htm
Old Jan 30, 2006 | 11:16 AM
C3VetteMan's Avatar
C3VetteMan
Cruising
Well before I go on, it's needless to say that the C3 Generation just further proved to me that it's the greatest generation of Vette's made, but I'm sure you all would agree with me anyways. Man, everytime I look at one, even though I'm not sure what year it is, it just reminds me how much Corvette has changed the way we look at cars.
But that's beside the point...
I think I've got a pretty good feel for what I want now. I'd say I'm probably going to stick with the 76, just for the sake of the Stingray name, along with the dome light placement, steering wheel column length, emblem placement, etc.
But I'm still not 100% on it. Being a big fan of horsepower, I'd like to have the best street/strip combo that I can put together...
Does anyone know what year has the best weight transfer for doing wheelies?
Thanks again,
Eddie
Old Jan 30, 2006 | 12:48 PM
proracr's Avatar
proracr
The engines for the 76 and 77 were the same, so that isn't a factor. The 77 had some improvements which would steer me to it. I have owned two 77's and loved the both.
Old Jan 30, 2006 | 11:27 PM
Mark PittPayne's Avatar
Mark PittPayne
If you can get either year with low miles and great shape you will be happy. If you want that Stingray badging, your choice is limited to the 76. You won't be disappointed either way. Good luck.
Old Jan 30, 2006 | 11:53 PM
John Ulrich's Avatar
John Ulrich
A quick way to determine a '76 from a '77 is the '77 has painted windshield trim vs the chromed trim on '76's
Later,
JU
Old Jan 31, 2006 | 12:31 AM
C3VetteMan's Avatar
C3VetteMan
Cruising
What about weight transfer for doing wheelies?
Old Jan 31, 2006 | 12:35 AM
TonySinclair
Only '68's are capable of doing wheelies...
Old Jan 31, 2006 | 09:12 PM
C3VetteMan's Avatar
C3VetteMan
Cruising
What about a 76 or 77?
To Having C3 Troubles...
Old Jan 31, 2006 | 09:21 PM
KALAWAY's Avatar
KALAWAY
If you're can't decide between a '75, '76, or '77, get the '75. It's got the more classic Stingray interior (steering wheel, gauges, etc). There's not much horsepower difference.
Old Jan 31, 2006 | 09:24 PM
1FUNVET's Avatar
1FUNVET
Hey my 1976 is for sale
Check it out my car for sale
or just shoot me a pm if your interested!!!
Old Jan 31, 2006 | 10:03 PM
TonySinclair
76 or 77's cannot pull wheelies, sorry. That option wasn't available in the later years...
Unfortunately, if you want to pull wheelies, your only choice is a '68...
