click on clock
Old Feb 1, 2006 | 10:32 PM
driver68's Avatar
driver68
Default click on clock
anyone come across a click sound on their clock every minute or so. my clock didn't work, only ran for a minute or so, i played around with the connection on the back and if i push the connector right down against the back of the clock it works, but i get the click sound every minute or so. very wierd.
Old Feb 1, 2006 | 10:34 PM
big_G's Avatar
big_G
It is a mechanical clock. The winding mechanisim is what your hearing. All is good.
Old Feb 1, 2006 | 10:35 PM
kona's Avatar
kona
Can't say i've had that experience but I did do the quartz conversion and the clock works perfectly now.
Kona
Old Feb 1, 2006 | 10:50 PM
mrit's Avatar
mrit
Anyone know the size of the nut for the wire on the clock? My '75 didn't have a nut on the back of it.
Old Feb 1, 2006 | 11:39 PM
vetteboy1976kr's Avatar
vetteboy1976kr
I believe it is a #8 nut. Usually that's what I start with and go up or down from there!
Old Feb 2, 2006 | 06:04 AM
fast idle's Avatar
fast idle
my 75 had the nut,but i soldered it this time,works great.
Old Feb 2, 2006 | 06:12 AM
PEPTO77's Avatar
PEPTO77
I agree, clicking noise is the winding mechanism in the mechanical clock. I think it runs on a set of points and that is what "clicks".
Old Feb 2, 2006 | 08:42 AM
Edzred72's Avatar
Edzred72
There are two contact points. One is stationary that has voltage, and one on the end of the winding spring. When the point contacts meet, voltage is applied across both, which then pushes the winding spring mechinisum point to it's max travel, away from the stationary point. (click) This winds the spring. As the clock ticks, the spring slowly unwinds bringing the spring point back into contact with the stationary one....(click...rewind) probably once every minute or so. Clean up those two contacts with an ignition points file, clean up the internals and lightly oil, and make sure your grounded...should work!!!!
Eddie
To click on clock
