Most authentic doorpanels
Old Feb 6, 2006 | 06:48 PM
Porch40's Avatar
Porch40
Default Most authentic doorpanels
I'm looking to replace the deluxe door panels on my 74. I'd like to get the most authentic color,grain, & texture since the rest of the interior is in good to excellent condition. I've seen nice looking reproductions at car shows but the texture and appearance were slightly different than stock. Does anyone have a recommendation ? Any close up pictures of those they have used ?
Also, for interior painting of the hard plastic parts like the back window frame, seatbelt housing, etc. are Eckler's or Eastwood paints a good choice ? I used Eckler's silver about 20 years ago and was really pleased with the results.
Thanks for your thoughts,
Scott
Old Feb 6, 2006 | 08:42 PM
icanfixitforyou's Avatar
icanfixitforyou
Hi, I don't know about the panels, but I used some of the Dupli-Color interior vinyl spray dye (paint) and it matched my 79's interior perfectly. I was also very pleased with the fast dry time and durability on my flexible center console. I also tried it on a piece of primed scrap metal and found that it also adhered very well (I couldn't scrape it off with my fingernail no matter how I tried). The "Desert Tan" was a perfect match for my tan/camel colored interior. It is available at most auto parts stores - I got mine at Auto Zone - and it only cost about 5 bucks, compare that to Eckler's 20 plus dollars. And no I don't work for Dupli Color but if they want a spokesperson....... and the money's right.....
Old Feb 6, 2006 | 08:46 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Dupli-color interior dye stuff works great and looks great.
Old Feb 7, 2006 | 01:18 AM
7T1vette's Avatar
7T1vette
If you have mild wear or color fading, the vinyl dye idea is the way to go. If you have significant damage to the vinyl, you have a number of choices. 1) buy new replacment panels with or without hardware...most costly but easiest option; 2) find someone in the business of vinyl repair (car dealers use them all the time)...second costliest option, but you still have the original panels; 3) re-skin the panels with new vinyl skins...cheapest option, but you won't have any hair left on your head [from pulling it all out]. Corvette America still sells the skins for less than $100 a set. Buy the recommended glue and follow the instructions precisely. Oh, the tough part is figuring out the sequence of putting the skin on your panel. You get one shot, and you can't shift it after its down. (Can you figure out which way I went?)
Old Feb 7, 2006 | 07:33 AM
caseybandy7777's Avatar
caseybandy7777
if your looking for new Al Knoch is the only way to go. They pay great attention to detail. http://www.alknochinteriors.com/catalog.htm
Old Feb 7, 2006 | 10:31 AM
kona's Avatar
kona
I would have to agree that Al Knoch while pricey does has excellent interior products.
Kona
Old Feb 7, 2006 | 10:43 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I used Al Knoch door panels and carpet in my car. I was not shooting for perfect reproduction but they do look pretty good. The backing on my door panels are not fiberboard but a hard plastic that should hold up for a long time.
Old Feb 7, 2006 | 12:01 PM
markdtn's Avatar
markdtn
Old Feb 7, 2006 | 12:46 PM
NHvette's Avatar
NHvette
I'm thinking about getting the door panel skins from Corvette
Central. I've heard too many stories about people needing
to trim and muscle their new molded plastic panels into place.
My panels need some structural repair, and the new vinyl skins
will cover the repairs to my panels that I KNOW fit well.
Has anyone used these ? Experiences ? Comments ?
http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
Thanks, Dave
Old Feb 7, 2006 | 02:53 PM
BarryK's Avatar
BarryK
go with Al Knoch or you are sure to be disappointed otherwise.
al may not be the least expensive but he is BY FAR the best stuff out there.
Here is a hint for you....... look up Wally Knoch who posts in the C1/C2 forum under the name Ironcross. Wally is Al's brother and also is a distributor for the Al Knoch products. Wally gives a discount to forum members, usually around 20%.
To Most authentic doorpanels
