Flippin speedometer.....
Old Feb 7, 2006 | 06:22 PM
fl_rider's Avatar
fl_rider
Default Flippin speedometer.....
I was driving North on Highway 12 out of Illinois yesterday when my speedometer suddenly started twitching between 50 and 80 miles per hour.
My first thought was not a good one but then I calmed down and started to think things through.
I finally arrived at the conclusion that the speedometer cable must be the cause of the whole thing.
I got home and searched the forum and the general concensus of the threads supported my conclusion. That is when I started patting myself on the back for being such a clever fellow.
This morning on the way to work I could hear a ticking noise that increased in frequency as I drove faster. It was right in time with the swings of the speedometer needle. That is when I noticed the odometer wasnt moving any more. So much for my THEORY about the cable.
Sooooooo... while I am pulling the dash to get the speedo out I guess I might just as well do the carpet and get the A/C up to snuff.
I WILL be checking in for moral support on a regular basis when I start this.
Old Feb 7, 2006 | 07:27 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
It's not that tough a job. Drop the column and pull the dash cap for better access. Here's 2 good people that can fix that speedo:
http://www.corvetteinstruments.com/
or:
VetteInstruments@aol.com/favicon.ico
I've had good dealings with the latter...
Old Feb 7, 2006 | 10:04 PM
fl_rider's Avatar
fl_rider
Default Thanks!!
I appreciate the insight.
Thanks again
Chris B
Old Feb 7, 2006 | 11:14 PM
7T1vette's Avatar
7T1vette
OK, gang. He's goin' for the speedo and carpet. My guess is that the entire interior will be done before its over! What say?
Old Feb 8, 2006 | 03:40 PM
SteelCityBlue's Avatar
SteelCityBlue
or:
What can go wrong with the speedo? It doesn't spin? I thought it has to be a broken cable or the gear?
Old Feb 8, 2006 | 03:45 PM
fl_rider's Avatar
fl_rider
It is the gear that drives the odometer....
or I should say used to drive the odometer.
Old Feb 8, 2006 | 04:17 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Ive got exactly the same problem
and ill be doing ther carpet upgrade at the same time as well
Misery loves company
To Flippin speedometer.....
