JB Weld
Old Feb 22, 2006 | 06:38 AM
babyiza73's Avatar
babyiza73
Active Streak: 90 Days
Default JB Weld
I have heard of this JB Weld stuff and want to know if I can use it to attach a bracket to the condensor rad on my DD. What exactly is it and where in Canada can I get it.
Thanks in advance
Mike
Old Feb 22, 2006 | 06:54 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
It's a 2 part epoxy putty-glue. Home Depot, Sears Hardware, probably Walmart even. There's even a quick drying 4 hour mix now. Secret I've found, let it dry a looong time. When dry though, it's very very hard.
Doesn't take extreme heat (500°) too well.
Old Feb 22, 2006 | 07:56 AM
Frankenvette's Avatar
Frankenvette
Great stuff for those of us who are welding impaired?
Old Feb 22, 2006 | 09:42 AM
Paul L's Avatar
Paul L
You can get it at Canadian Tire.
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
I think in Canada it is sold under the name "JB Weld-Eh"
Old Feb 22, 2006 | 10:39 AM
NHvette's Avatar
NHvette
It might not be great for attaching a broken bracket.
You'll need a good amount of surface area to hold well,
and the situation is compounded by extreme temps.
If you do try it, I would try to scuff the surfaces and make
sure it is super clean before applying.
Good Luck
Old Feb 22, 2006 | 11:22 AM
big_G's Avatar
big_G
Old Feb 22, 2006 | 11:30 AM
Sprzout's Avatar
Sprzout
Actually, that depends on the particular type of JB Weld, since it comes in different strengths.
If you're planning on using it for a radiator bracket, you want to look for stuff called "JB Industro Weld".
Stuff's rated to 600 degrees F, and actually works well on cooling applications. I've got some that's in our thermostat housing on our '67 Jaguar, and it's holding up amazingly well. We figured we'd give this stuff a shot, since the previous owner had used some epoxy to fill in the pitting and a hole that was in the housing; for us to replace the part it was $100. We used Industro Weld and it cost us $10.
The downside to the Industro Weld is that it takes a MINIMUM of 24 hours to set and harden fully. However, when it's done, it can be sanded and painted; we smoothed the stuff out with sandpaper and a dremel tool to get it nice and smooth, and it took about a week of applying the Industro Weld to get it to where it built up the housing back to original shape.
Old Feb 22, 2006 | 01:12 PM
John Ulrich's Avatar
John Ulrich
I used it on a gold air converter check valve coming off the exhaust manifold on an '81. It rusted out on the bottom but you could not see it...I was tracking down what I thought was a lifter noise and found it.
It's still holding 15 years later!!!
JU
Old Feb 22, 2006 | 10:35 PM
shafrs3's Avatar
shafrs3
I tried this stuff on a stripped intake thermostat housing bolt hole, it didn't hold. Ended up using some aluminum brazing rod to fill and re-tap the hole.
Old Feb 23, 2006 | 11:01 AM
Z51JEFF's Avatar
Z51JEFF
Ive used this stuff alot in the past.Whats good about this stuff is it washes off with soap and water,but once it sets up,forget it.Its like cement once dry.
To JB Weld
