Another 68 Corvette Question
Old Mar 1, 2006 | 08:50 AM
IDOXLR8's Avatar
IDOXLR8
Default Another 68 Corvette Question
I've seen 68-69 with a front heat shield like this http://cgi.ebay.com/ebaymotors/68-69...QQcmdZViewItem . Mine doesn't have this just a two triangle metal shields that screws to the frame on the left and right, AL.
Old Mar 1, 2006 | 11:01 AM
682XLR8's Avatar
682XLR8
That ebay pic looks about right. My 68 came with the same shields, they were too rusty/dented to reuse, so I made another set out of sheet steel. Your factory assembly manual show how they mount
Old Mar 1, 2006 | 12:37 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
There's a repro source for brand new ones I've sent you. They are at Bloomington Gold each year.
Old Mar 2, 2006 | 09:00 AM
IDOXLR8's Avatar
IDOXLR8
Default Another 68 Parts Question
Randy, thanks for the link! That company sells great parts, I didn't know they sold the shield kits.
I'm still puzzled about the the shields on my 68, mine never had that style shield. Mine had a triangle shaped metal shield at both front corners of the frame rails just in back of the front wheels. I know mine came this way because there are no holes drilled for the brackets for the ones in the picture, just mounting holes for the ones bolted to the frame , AL.
Old Mar 2, 2006 | 09:48 AM
vettepilot68's Avatar
vettepilot68
AL...mine are like yours. I know mine are stock. They dont look anything like those you point out on ebay...mine are more triangular.
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
As I understand '68's (and, like women, you never completely understand '68's) some had those shields, some didn't. I'll try to scan a couple of pages from the AIM and send those to you for reference.
Old Mar 2, 2006 | 10:00 AM
rihwoods's Avatar
rihwoods
Took this photo ......can't remember year,but think 68-70
Old Mar 2, 2006 | 10:14 AM
IDOXLR8's Avatar
IDOXLR8
You'll love what I did. The ones that were on the car were rusty and in bad shape so I took a piece of polished stainless steel used on like soda machines and cut out the correct shape and they look cool! Its funny I saw a listing for the mid year Corvette big block showing the same ones that were on my car, AL.
Old Mar 2, 2006 | 10:23 AM
IDOXLR8's Avatar
IDOXLR8
Okay, I think I understand it now. The early 68s used the #B2509A http://www.cscreproductions.com/68_82_4.htm and the late ones into the 69 model year used the B2510 http://www.cscreproductions.com/68_82_3.htm AL.
Old Mar 2, 2006 | 10:33 AM
IDOXLR8's Avatar
IDOXLR8
Here is the part that makes no sense my coupe was built on 4/29/68 and I thought this would be a mid or late production. My Corvette has the first design splash shields and seat backs and second design mirror position, door panels with real pull handles, wiper over ride system, and center windshield frame cover. Windshield date codes in late 67 and the others in mid 68 , AL.
Old Mar 2, 2006 | 02:18 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
I may have been confused and confused others. I thought of the heat shields below the floor pan, not the splash shields as depicted in rihwoods picture.
Old Mar 2, 2006 | 02:24 PM
IDOXLR8's Avatar
IDOXLR8
So in short my car had no heat shields from the factory just two splash shields and the silver colored floor insulation, AL.
Old Mar 2, 2006 | 02:32 PM
rihwoods's Avatar
rihwoods
Not muddle topic up here,but think "splash" sheilds/heat shields serve same purpose...and the exterior floorboard insulation extends back to the crossmember..
This is my 69...
Old Mar 2, 2006 | 02:40 PM
IDOXLR8's Avatar
IDOXLR8
This is my 69...
I'm still lost in the 68ville . My 68 built on 4/28/68 has no shields on the forward part of the foor just the two triangle shield bolted the frame and the 69 uses the same set up as the 69 but the ealy 68s supposed to have a plastic shields at the firewall not metal AL.
Old Mar 2, 2006 | 02:47 PM
rihwoods's Avatar
rihwoods
Can you post pics of yours ? Also,there was a thread on this awhile back....there were some very good comments/info provided.....no mention of 68,though..
http://forums.corvetteforum.com/show....php?t=1270736
...Chuck may know the answer...
Old Mar 2, 2006 | 02:51 PM
IDOXLR8's Avatar
IDOXLR8
Here it is #B2509A http://www.cscreproductions.com/68_82_4.htm . BTW I'm going to shoot the web site guy some $ so I can post pictures the normal way, AL.
Old Mar 2, 2006 | 02:56 PM
rihwoods's Avatar
rihwoods
See my edit...
For pics,go to photobucket.com...upload from your computer,and you can post from there to this forum..use "img" code under your pics at that site...
To Another 68 Corvette Question
Old Mar 2, 2006 | 02:58 PM
IDOXLR8's Avatar
IDOXLR8
See my edit...
Okay, Thanks , I have a TON of Information to bring to the table for the 68 model year, AL.
Old Mar 2, 2006 | 03:34 PM
vettepilot68
Old Mar 2, 2006 | 07:40 PM
ksbunting's Avatar
ksbunting
Al,
Shoot me an e-mail when you get ready to post the TON of 68 Corvette stuff.
As you know, I am very interested and want to be sure I don't miss the post.
Thanks,
Kurt
