Roll Bar Questions
Old 03-05-2006, 03:03 PM
68 Yellow 468
68 Yellow 468's Avatar
Default Roll Bar Questions
I am looking at getting a roll bar for the 68 vert and have seen a few good ideas out there.
I was wondering:
1). The 'Shark Bar' with roll bar hoops that I have seen. ( http://www.speeddirect.com/index.aspx?nodeID=121 ) It looks good but I have not seen one in person. Is it heavy duty enough to help with a roll over event? I have read that it is not certified for 1/4 mile usage. Any feedback as to it's utility?
2). A four point. This seems to offer a greater amount of security in case of a roll over event. Would this absolutely be the way to go for protection?
3). I am not looking for a full cage even though I realize it would be by far the best just in terms of safety.
I appreciate the help.
Bryan
Old 03-05-2006, 03:14 PM
turtlevette
turtlevette's Avatar
St. Jude Donor '03,'11
the shark bar doesn't do anything for rollover. Just provides 5 point seat belt and camera mount.
The 4 point is the minimum needed for racing. You need to make sure you get the proper diameter usually 1.75 or better DOM tubing with a wall thickness of .120 or better.
Old 03-05-2006, 04:21 PM
sasnglass77
sasnglass77's Avatar
I have an Autopower one best pick i could find of it sorry it's blurry:
Yes you have to meet said thickness requirements if you intend to race, mine is only a 4 pt. if you gonna race mount your fire extin.
Old 03-05-2006, 04:22 PM
GrandSportC3
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Here are pics of my NHRA legal 6-point which clears the convertible top!!
Old 03-05-2006, 04:29 PM
Yellow73SB
Yellow73SB's Avatar
St. Jude Donor '07
GSC3 Can he do 12 point cages on c3's also?
Old 03-05-2006, 04:38 PM
GrandSportC3
The guy that did mine could do any amount of points you want!!
Old 03-05-2006, 04:42 PM
Corey_68
Corey_68's Avatar
Wow around here only a 6pt is considered "legal", this is for the road racing and NHRA tracks.
Old 03-05-2006, 04:52 PM
GrandSportC3
NHRA rules actually require 5 point rollbars to be legal to 10.00 with a coupe (or convertible with hardtop) if the firewall is unaltered..
Below 10.00 needs a full cage!!
Old 03-05-2006, 05:04 PM
Twin_Turbo
Twin_Turbo's Avatar
GS, that's the weirdest roll bar I've ever seen, if you sit in it, is your helmet higher than the roll car? Sure looks like it.
Old 03-05-2006, 06:30 PM
GrandSportC3
nope, the helmet is way below the rollbar.. The seat is about 3 to 4 inches lower than the factory seat!! With the factory seat, the helmet would be about the same height as the top of the bar..
The way that bar is setup is the only way to retain the convertible top and still be NHRA legal!! I haven't seen any other C3 Convertible that has a functional convertible top and a legal 6-point rollbar..
Old 03-05-2006, 07:06 PM
turtlevette
What the hail do you know about road racing or for that matter drag. Aren't you a show 'n shine guy????
i guess its a Naaa-orleans thing.
seriously, i have the 06 SCCA rulebook and i can't find where it says 6 point minimum.
Old 03-05-2006, 08:00 PM
sasnglass77
I know I couldn't run Giant's Despair in '97 because I didn't have a full cage. Would have been grandfathered in if I ran in '96. But that was BSP in a solo 1 event (hillclimb). *shrugs*
Old 03-05-2006, 09:58 PM
Corey_68
Corey_68's Avatar
Show N Shine?? I have a 15ft'er, don't belong to any car clubs and loathe entering cars into car shows. I'm an atypical Vette owner I guess.
I talked to the owner of the local track and he said if I wanted to race my car wheel to wheel I'd have to put in a 6pt. If I just want to run hot laps alone no roll bar/cage is needed. Just going by what the owner told me.??
Local track ---> http://noproblemraceway.com/
Old 03-05-2006, 10:23 PM
turtlevette
that looks like a fun track. Your car is too nice to race wheel to wheel. See if they have open test sessions. Its not racing you just pull over and let faster cars pass you. Go at your own pace and have fun. Thats what i do. It ain't racing.
Old 03-06-2006, 05:44 AM
breathial
breathial's Avatar
If you're going to a drag-racing track, then I'd suggest looking at the link HERE. There's a picture that describes the required roll bar needed, and for what ET categories.
Hope it helps.
To Roll Bar Questions
Quick Reply: Roll Bar Questions
