Engine decoding
Old Mar 17, 2006 | 08:50 PM
Smoke 1's Avatar
Smoke 1
Default Engine decoding
I am trying to verify a engine in a 74 vet. VI173chb. Casting # on block is 3970010. I just not sure what I have. Thanks in advance for any help!
Old Mar 17, 2006 | 08:53 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
you have the correct block. but recheck your engin perfix. it should be CLB for a 305ci, 195hp with a manual tranny, and ca emissions. alos do you have an early car?
Old Mar 17, 2006 | 08:58 PM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
Looking in the black book CHB is a 75 350ci 165hp, at w/ 3970010 as the block.......hope this info helps and is correct. WB
Old Mar 17, 2006 | 08:59 PM
Smoke 1's Avatar
Smoke 1
Default engine decode
.;....The other No. on the block is15S405859 I also have a auto trans. thanks
Old Mar 17, 2006 | 09:01 PM
Don Rickles
2017 C3 of Year
That number should match your VIN
Old Mar 17, 2006 | 09:05 PM
Smoke 1's Avatar
Smoke 1
Default engine
.... Thats what I was afraid of, It does not. how can I find what this engine goes to?
Old Mar 17, 2006 | 09:06 PM
James.70's Avatar
James.70
From: Show me a cold beer and I will show you a happy man Maryland
v is for flint plant, think it is 11 not i1 which is a november date. 73 is not right becuse this should be the day of that month....like the 13th or something....unfortinatley chb is a 74 code for an l48 350/165 with 8.5.1 comp and a 4bc with auto trans...not a 75 code, but my book could be wrong. could it be clb, that is a 74 code. as far as the block # it should start with a one and the third digit should be a letter, at laest that is what it says in my numbers book. Maybe some other guys can help clear this up. Good luck
Old Mar 17, 2006 | 09:12 PM
James.70's Avatar
James.70
15S is 75 that is what the second number 5 stands for.
Old Mar 17, 2006 | 09:13 PM
Don Rickles
2017 C3 of Year
Again it say's it's a 75 built in Nov. of 74
It should be more like 1Z37J5S405859
Old Mar 17, 2006 | 09:44 PM
Smoke 1's Avatar
Smoke 1
You were right! after some more scrubbing....VI1l3chb. Thanks
Old Mar 17, 2006 | 11:27 PM
James.70's Avatar
James.70
v is for flint plant, think it is 11 not i1 which is a november date. 73 is not right becuse this should be the day of that month....like the 13th or something....unfortinatley chb is a 75 code for an l48 350/165 with 8.5.1 comp and a 4bc with auto trans...not a 74 code, but my book could be wrong. could it be clb, that is a 74 code. as far as the block # it should start with a one and the third digit should be a letter, at laest that is what it says in my numbers book. Maybe some other guys can help clear this up. Good luck
I corrected 2 typos on years I had switched
Old Mar 17, 2006 | 11:30 PM
James.70's Avatar
James.70
so it is built november 13th 1975
To Engine decoding
