Rear Leaf Spring
Old Apr 8, 2006 | 09:07 PM
76vette1's Avatar
76vette1
Default Rear Leaf Spring
All I have seen or heard is 7 or 9 leaf springs in C3's. I just pulled mine out of my 76 and it has 10 leaves. Does the bottom one that bolts to the trailing arms not count? Or do I have an aftermarket or modified spring?
Old Apr 8, 2006 | 09:14 PM
SwedeAWACS's Avatar
SwedeAWACS
My 78 Gymkhana suspension has a 5 x leaf spring, but when I took it apart, I ended up with 6 x metal pieces. I think the short 6 inch long piece doesn't count. Based on that, it sounds like you have a 9 leaf spring, with that small piece on top. Maybe that helps you.
Swede
jomor's Avatar
jomor
My 81 4 speed has 9
Old Apr 8, 2006 | 09:21 PM
76vette1's Avatar
76vette1
Swede
The top leaf is about 12 inches long. The leaf on top of the bottom one looks different from the rest. The top eight all have their corners turned up a little, while this one is flat and straight. Its not a big deal, I'm just curious. It's going to get rebuilt anyway.
To Rear Leaf Spring
