Rear end decoding?
Old Apr 11, 2006 | 08:06 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Rear end decoding?
Where can I get info online about the rear end codes stamped on the case? I did a google but couldn't find anything.
Old Apr 11, 2006 | 09:28 AM
Allen_396's Avatar
Allen_396
In addition to that question.......
Where is the code stamped?
Can you see it by looking under there, or is it hidden by a spring or something?
I'd like to confirm what my '69 has. My guess is 3.36 posi, but I don't know for sure
Thanks!
Old Apr 11, 2006 | 10:44 AM
Garys 68's Avatar
Garys 68
Allen,
The code you want is stamped on the bottom, between the strut mount and the spring.
Old Apr 11, 2006 | 11:20 AM
Z-man's Avatar
Z-man
Here you go.
This page shows the various numbers for 1970.
These show what they looked like on my diff...
It's hard to read these things. I had to brush mine off with a wire brush before I could read them. The letters are shallow. Mine are 2 CAM 3-26-70 W. This stands for 3.36:1, positraction, March 26, 1970 - Warren plant.
Old Apr 11, 2006 | 11:55 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
Originally Posted by Z-man
Here you go.
You have anything for 1969 or would they be the same?
Old Apr 11, 2006 | 07:08 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
I think I found it. The '69's are the same except without the first letter "C."
Old Apr 11, 2006 | 07:35 PM
Z-man's Avatar
Z-man
Yes - (as I remember)
Old Apr 11, 2006 | 09:30 PM
redvetracr's Avatar
redvetracr
Thanks!
in the time it takes to jack up your car, climb under and clean the crud off you could spin a wheel and count the revolutions of the driveshaft...the ONLY real way to tell what gear you have considering how many Corvette differentials have had a gear change!!
...redvetracr
Old Apr 11, 2006 | 09:33 PM
redvetracr's Avatar
redvetracr
Len,
Wouldn`t it be easier to post the code you are looking for and ask someone decode it for you?? Those codes are listed in the front of the GM parts counter P&A/30-B
...redvetracr
Old Apr 12, 2006 | 06:46 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
I'm not looking for one in particular, just wanted to confirm one I ran accross. I don't want to ask anyone to decode each time I find one.
To Rear end decoding?
