I`ve read that a th400 uses 20% of your engines power thru drivetrain loss. I have a 75 l48, 165 hp. So that would mean about 30 hp. I`ve made some mods and now I`m about 300 hp at the flywheel. Does that mean the drivetrain now requires 60 hp. This weekend I`m putting in a 383 in exess of 400 hp. So now does it take 80 hp? It doesn`t make sense.
I think your right. They just throw those #s out as general percentages based on some baseline horsepower.
Have always wondered about those % losses. Why would it take more HP to turn the transmission just because you engine makes more power? So it takes 50 hp to efficently operate the transmission. If you engine makes only 100 hp, that would be a huge loss. But it your engine makes 1000 hp then why would it take more than 50 hp to efficently operate the transmission?
Guess the good thing is that everyone with that transmission has the same loss
Its not a matter of how much it takes to operate the transmission. The Transmission TRANSMITS power from the engine to the drive line. As with any transmission system ( sattelites, CB Radis, Walkie Talkies, Alison and CAT drives) they have losses (% of effencies) Not all the power generated in the engine makes it to the rear wheels. If you puch 100hp thru a 80% tranny you get 80 to the wheels. Same tranny, now crank the throttle to 300hp out, now you lose 60hp in the transmission, heat goes up a lot, each HP is 314 wats, 314x60 = 18840 watts. Thats a lot of heat. One of the reasons they invented a Lockup converter. Without the slippage that makes a converter work, its a lot more effecient. Same deal with a clutch, less slippage over time, less heat generated, more efficient.
Automatic transmissions have losses compared to manual transmissions because manual transmissions physically link the engine to the driveshaft. Automatic transmissions transmit the power from the engine to transmission through a fluid, which causes the two to slip against each other. There is no mechanical link between the engine and transmission. All things being equal, ATs do not "use power", but incur losses when compared to manual transmissions. Losses become evident at constant RPM when compared to manual transmissions.
You get some percentage of loss that is greater than zero, and less than ridiculous.
The major losses thru an automatic tranny are for the hydraulic pump (several horsepower), the inertia losses for the rotating parts, and friction losses. In no way does that eat up 20% of your total engine power. The auto tranny does help out via torque multiplication (due to torque converter/stator design), so it's not all bad news. Mileage is a bit worse than with a standard gear box, due to these additional losses.
2016 C2 of Year
2015 C3 of Year Finalist
There are drivetrain losses in horsepower for manual transmissions also. They are not as great as they are for the auto trans but still significant. You are never going to get all the horsepower that you have at the crank to the rear wheels in an auto or a standard. The loss, while greater in an auto than a standard, is not 20% greater in the auto.
thats enough rant for now
.....totally agree w/ SIXFOOTER......whether it's heat or resistance, the power loss number rises when more force is generated: a 4cyl. engine loses little HP when corked to a 2" exhaust pipe, but a 700 HP engine may lose 100 HP through that same pipe.....
