tools u must have
Old May 9, 2006 | 11:28 PM
onaqwst's Avatar
onaqwst
Default tools u must have
i'm sure we all know that we need wrenches/sockets/screwdrivers/etc....but for the newbies that are just getting into there projects i would recommend a few tools that you must have
1. a dremel with heavy duty cutoff wheels...has to be heavy duty ones...the other ones will just snap
2. a saw-zall.... for all the stubborn shyt....
3. a "dammit" tool....preferrably a squeeky hammer or a bouncy ball... so u can throw it after u bust your knuckles trying to break loose the shock mount
b
Old May 9, 2006 | 11:41 PM
rosslato's Avatar
rosslato
how bout a TORQUE WRENCH! u don't even possess 1 of them
Old May 9, 2006 | 11:43 PM
oregonsharkman's Avatar
oregonsharkman
Rubber hammer, 2nd the cut-off tool, bench vice, 12v test light.....too many other to list
Old May 9, 2006 | 11:47 PM
chris73cpe's Avatar
chris73cpe
impact wrench, prefereably pneumatic.
pullers and pickleforks are essential for suspension work too
Victor's Avatar
Victor
Impact wrench or a set of 24" biceps
...I have neither so I guess I'm screwed
Old May 9, 2006 | 11:55 PM
TonySinclair's Avatar
TonySinclair
Old May 10, 2006 | 12:02 AM
onaqwst's Avatar
onaqwst
i don't need a torque wrench...remember i eyeball it anyways so i know when it snaps......
b
rosslato's Avatar
rosslato
Originally Posted by TonySinclair
"a place for everything and everything in it's place". i thought i was a hang it up freak but u put me to shame
Old May 10, 2006 | 12:04 AM
TonySinclair
Those are just my watch repair tools...
Old May 10, 2006 | 12:06 AM
onaqwst's Avatar
onaqwst
the clock doesn't werk in a vette .....they deleted that option in 68
Old May 10, 2006 | 12:19 AM
BLUSHRK's Avatar
BLUSHRK
my clock is like my last girlfriend. Works when it feels like it.
Tools? how about a digital camera...I take pics that way when I forget how something was when I started, I can put it back the right way! Like spark plug wires and vacuum lines.
Old May 10, 2006 | 12:35 AM
Sprzout's Avatar
Sprzout
Universal joints in 1/2" and 3/8" drive, and wobble end extensions.
I found those were INCREDIBLY helpful to get the bolts on motor mounts in from under the car.
One of those squeeze grabbers; they're the things that are spring loaded on a long, thin cable, and squeezing them causes the skinny metal fingers to come out to grab dropped nuts/bolts/sockets that fall in those nooks & crannies that they don't drop to the ground from.
I also bought a really nice tool that's basically a magnet on wheels; it's great to roll under the car and pick up washers/nuts/bolts that fall underneath. It's great when there's oil, grease, cat litter, etc under the car and you don't want to get gunked up.
Old May 10, 2006 | 12:37 AM
76custompaint's Avatar
76custompaint
Go to Sears, buy every tool they have. I guarantee you will only have to buy 1 new tool per project after you have done this.
Seriously though, a good torque wrench that goes to 150 ft-lbs, a torque wrench that goes from 1 ft-lb to 15 ft lbs, a torque wrench that goes from 15-50 ft-lbs, a good socket set, a good wrench set, a dremel, a sawzall, a welder, a plasma cutter, an oxy-acetylene torch, a screw driver set (phillips and flat blade), some paint scrapers, an impact driver, an air wrench, an angle grinder, a table saw, a gear puller. That will get you through most things, but not everything, be prepared to buy a lot of tools depending on how far into your car you get.
76custompaint
Old May 10, 2006 | 01:16 AM
onaqwst's Avatar
onaqwst
wtf u need a table saw for...... i used mine for my audio setup....but wtf.....
b
Old May 10, 2006 | 01:21 AM
TonySinclair
I put a metal blade in mine and cut panels, bar stock, etc.
Old May 10, 2006 | 01:24 AM
onaqwst's Avatar
onaqwst
ok...... i just had a chop saw for metal...... i cut aluminum on a table saw and it sucked.... i just go to the steel shops and have them shear it now....easier...i just tip them
b
Old May 10, 2006 | 01:46 AM
76custompaint
We use the table saw for the bigger aluminum sheets that we can't fit in the chop saw, it works well for that as long as you have the blade and enough motor to do it.
To tools u must have
Old May 10, 2006 | 01:48 AM
gator79's Avatar
gator79
tools are like sex you can never have enough
Old May 10, 2006 | 02:27 AM
vho69's Avatar
vho69
case of beer
Old May 10, 2006 | 05:07 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I think my dentist used some of those.
