tools u must have
BigBlockk
Later.....
OK, Plato.
Let's see you rebuild your trailing arms using nothing but your brain.
Saftey wire/Pliers
Bead roller
Sheet metal brake
Pipe bender
12 ton press
10 ton Portapower
3/4 drive sockets
Belt/drum sander
Pipemaster
Assorted hydraulic Jacks
Pneumatic over hydraulic rivit gun (1/4 inch) Supply of rivits
Router
Taps Dies
Magnetic base dial indicator
Supply of: nuts, bolts, washer, o rings, cotter pins, zerk fittings, an fittings,
Wire, heat shrink tubing, terminals, connectors, steel, aluminum, Otiker Clamps, Adel Clamps, hose clamps,
WD-40
Anti Sieze
ZIP TIES
PanaVice
DVM
Oscope
metal files
dental pics
Mity Vac
Drill doctor 750
Snap ring pliers
Allan wrenches, Sockets, Tork sockets, Crows foot Wrenches, Tubing wrenches
BIG pair of Channel Locks
Set of Carbide bur's
set of hole saws
Set of Greenlee punches
Good Cordless drill
Millwalkee 1/2" hole shooter
Air nailers, staplers, grinters drills saws, shears, nibblers
And so many home made pullers installers brackets...
Now I have to go to the garage and clean....
Do you believe everything you see/read on the Internet?
P.S. - I went to your school's website and found this pic of you...good lookin' chap!
And I searched your name in the air force and found a picture of you in uniform.
1. Good quality Roller Ball Pen.
2. Checks in the Checkbook.
3. Wife with good job to replenish the Checkbook weekly.
I knew a guy like that once...Wife bought him a Viper and a '32 T-Bucket.
He blew it by getting caught in bed with his neighbor and her friend.
I'll agree, though, a gigantic checking account balance would be good to have...
BFH
