Continuous drain
Old May 29, 2006 | 10:03 AM
chobbs's Avatar
chobbs
1st Gear
Default Continuous drain
I let my "reputable" mechanic change my timing chain and now My battery will not stay charged for more than a day at the most.I have tried everything and can't figure where the hell the "battery drian" is coming from. I have taken every fuse out and the battery still gets drained. Any ideas?
BTW: 74' 350 small block w/ac
Old May 29, 2006 | 11:29 AM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
This may sound crazy....my battery drain was......the little light in the center glove box did not go out when the glove box door was closed. I adjusted the "switch" in the glove box (sitting in the dark) and have since stopped buying batteries !
Old May 29, 2006 | 11:37 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Alternator? Chuck
Old May 29, 2006 | 11:45 AM
carl a's Avatar
carl a
put one of these in-------see post above battery disc switch---- j c whitney-- until you trace down draw this will keep battery from draining---------------------------------------------------------
Old May 29, 2006 | 11:56 AM
litevette's Avatar
litevette
These are also cheap, easy to use and install:
http://herrington-catalog.stores.yahoo.net/m971.html
Old May 29, 2006 | 02:38 PM
carl a's Avatar
carl a
i see those all the time at car shows for a buck, problem i had w/ them was when opening circut for parking at indoor car shows the connection makes and breaks,sounding the alarm. when you turn that **** 2 plates get a small gap to stop current flo,problem is they also make sending current thru again causing the annoying alarm to go thru its annoying cycle of noise,the blade type once opened stays opened, but there a little more pricy at almost 30 bucks a pop
Old May 29, 2006 | 02:44 PM
carl a's Avatar
carl a
if theres no load how can it drain? unless its not even charging. id make sure the systems charging then id open the circut and see what happens if it still is dead with the complete electrical disconected(by means of a disc switch or just removing the termanils for a few days) my vote would be a weak cell draining the rest of them,,,i had a new battery do this,,,first i put in the disc switch,,went back to the car a few days later and it was dead,,,how can a new battery be dead in 2 days with no draw at all on it???? because if one cell is weak it will draw the rest down with it..a good garage will be able to test the cells with a hydrometer type tool to check the electrolite one step at a time and you;ll figure it out
Old May 29, 2006 | 08:12 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
does your car have an electric choke? i wonder if he screwed up the wiring some how and hot wired it to alternator?
To Continuous drain
