Slick 50
Old Jun 7, 2006 | 01:45 AM
LS WON's Avatar
LS WON
Marvel Mystery Oil
Old Jun 7, 2006 | 09:35 AM
SJW's Avatar
SJW
Re: Slick50:
http://www.ftc.gov/opa/1996/07/slick.htm
http://www.ftc.gov/opa/1997/07/slick.htm
and there are many more web pages related to Slick50 on the FTC's site...
Be well,
SJW
Old Jun 7, 2006 | 10:24 AM
fauxrs2's Avatar
fauxrs2
Clearly, slick 50 is better than a quart of sand in your crankcase
Old Jun 7, 2006 | 10:48 AM
SJW's Avatar
SJW
Yah... but sand costs a lot less...
Be well,
SJW
Old Jun 7, 2006 | 10:54 AM
kaamacat's Avatar
kaamacat
For the "older" cars I like to use Valvoline's VR1 series with high zinc content for bearings. (Using 10w30 now in my 72'C3).
As for cleaners, Techron is great stuff on a full tank just before an oil change. (or just run Chevrons fuel for a few tanks and that works fine also)
Marvel Mystery Oil (that someone mentioned) is excellent if you are suspect at all that your engine has oil crud inside. Run it as one of your quarts for an oil change (with a 10w30) and for 15mins. Will clean your lifters and is safe.
Old Jun 7, 2006 | 12:58 PM
LS WON's Avatar
LS WON
Originally Posted by SJW
Re: Slick50:
Be well,
SJW
Very interesting Is it the same as Duralube?
Old Jun 7, 2006 | 01:49 PM
Ed Blue 03's Avatar
Ed Blue 03
Originally Posted by smangs
I was more thinking about fuel additives that clean your carb/injector
My wife's Volvo occasionally needs a fuel system additive to clean the injectors. My experience has been that Valvoline Complete Fuel System cleaner works better than the others.
Old Jun 7, 2006 | 02:13 PM
smangs's Avatar
smangs
Thank you very much for all your input. Basically, I decided to stay away from oil additives but do a carb/injector cleaning every once in a while.
Old Jun 7, 2006 | 02:43 PM
SJW's Avatar
SJW
I don't know the answer to this.
Be well,
SJW
Old Jun 7, 2006 | 03:07 PM
bashcraft's Avatar
bashcraft
Originally Posted by rihwoods
A pound of hambuger will quiet a rear end down...
Do you think hot dogs would work too? They'd be a lot easier to get in that little hole.
Old Jun 7, 2006 | 03:33 PM
JustForFun's Avatar
JustForFun
Marvel Mystery Oil is actually a great product. Have seen it break free many frozen/sludged lifters as well as PCV valves. Honestly for what they claim its pretty good stuff
Old Jun 7, 2006 | 03:51 PM
rihwoods's Avatar
rihwoods
I actually did that once to a beater....hot dogs would be easier...
