Is anyone else actively restoring?
Old Jun 18, 2006 | 07:44 AM
  #61
AlCherry's Avatar
AlCherry
What a helluva thread. I saw so much in the photos posted. Going to the shop!
Old Jun 18, 2006 | 10:03 AM
  #62
gator79's Avatar
gator79
Originally Posted by Twin_Turbo
I'm also restoring mine although I must say here on the other side of the pond it's tough getting the correct factory parts.............
moved to the attick
Here's my resto
I did not think you had any stock parts on your car seems like you built just about everything
Old Jun 18, 2006 | 11:33 AM
  #63
Twin_Turbo's Avatar
Twin_Turbo
that's what I said..it's hard moving them to the attick..a lot of work
Old Jun 18, 2006 | 03:01 PM
  #64
VETTEVIC's Avatar
VETTEVIC
Originally Posted by ikwhite
Vic what did you use to get the under belly and firewall to that shape. Looks like you might have used some sort of media blasting looks great anywho.
K
What you are seeing is the completed underside and firewall. I replaced the floor pans with aftermarket pieces from Corvette Central and welded to the existing tunnel and rebuilt the firewall and reinstalled. Then I used Por15 on the floorpans in and out, Etching primer, undercoating and then finished with some light primer and trunk spatter paint to get the look I wanted. Still waiting on the battery cables so I can put those on before I put the body on the frame.
Old Jun 18, 2006 | 06:48 PM
  #65
Demonic Possession's Avatar
Demonic Possession
I'm working on my '75, not really restoring it. Well, I guess you can say I'm restoring the frame, but it's not a off the frame restoration...and I'll be putting a new engine soon...
Old Jun 27, 2006 | 01:47 PM
  #66
Penn State's Avatar
Penn State
7th Gear
Wow i really didn't think i would get this kind of response! Talk about pure motivation just looking at these cars. I'll post pics soon of our frame.
Old Jul 7, 2006 | 09:10 PM
  #67
corvettecris's Avatar
corvettecris
Here is mine so far. I have been working on it after work on the week days for a couple weeks now. Sandblasting late next week I hope.
The body dolly:
Chassis:
Old Jul 7, 2006 | 09:12 PM
  #68
corvettecris
Oh, what is everyone using on their frames paint-wise? I want powder, but I think it is going to be out of my budget.
Old Jul 7, 2006 | 09:57 PM
  #69
Crazy81's Avatar
Crazy81
I'm going to paint mine with epoxy paint.
Old Jul 7, 2006 | 10:11 PM
  #70
ksbunting's Avatar
ksbunting
Hang in there and don't get discouraged. I just finished my 68 and what I thought would take a year or two took ten long years. Just started driving it on sunny days a few weeks ago and IT WAS ALL WORTH IT.
You will reach the same point and be so proud of what you have done.
Many of us have been where you are. Don't loose sight of the goal.
Come to this forum for inspiration whenever you get down and feel like it will never end.
Kurt
Old Jul 7, 2006 | 11:38 PM
  #71
The3's Avatar
The3
I guess i'm restoring. Just pulled the engine and tranny last weekend. Finished putting the engine and tranny together this evening. While the engine is out I'm going to rebuild the front suspension. I have found that once you start rebuilding one thing another issue pops up. So much for finishing on time and under budget. Good luck and keep working on it.
Old Jul 15, 2006 | 11:38 PM
  #72
bwellisley's Avatar
bwellisley
Default getting closer...have a couple of questions
wish i was as far as some of you, and had the ability to do a frame-off, maybe in the future i can go back and do it...
i'm just about done with my 1st engine build! my 68 has a 69 350 engine. i'm preparing to do the timing prior to the 1st start. i have an engine dress-up kit, holley carb, and hooker headers coming from summit. i need to figure out what all else is needed once i get the engine ready to turn. i'll also be ordering a new clutch system this week. i'll be hookin' up to a 4spd muncy (orig to car).
?, anything i should do to prep the trans?
also, i noticed what looks like a power cable coming out from under the right side motor mount that has been cut off...what is it? i have an assembly manual ordered but haven't received it yet.
thanks
Old Jul 16, 2006 | 04:26 AM
  #73
corvettecris
It is the grounding cable for the engine. You will need to get a new one for sure!
Old Jul 16, 2006 | 08:09 AM
  #74
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
I'm at the beginning of my frame off, just pulled the front clip and getting ready to pull the rest of the body off.
Yesterday I pulled the steering column and instrument cluster.
Old Jul 16, 2006 | 08:50 AM
  #75
82MDVette's Avatar
82MDVette
Default My '82 Project
'82 Vette. Frame-off with just about every nut and bolt new. I have been working on it for the past 1 1/2 years and she is finally coming together nicely.
Lifting the body after using a razor blade to strip the paint
The original Cross-Fire engine
Body dolly, thanks to the Forum Members for the specs!
The stripped frame being shipped off for sandblasting & powder coating
Body being shipped off for bodywork
Notice the emblem wholes filled. I am going with airbrushing the factory emblems prior to clearcoat
My Buddies Father owns the shop and I stop by everyday to check the progress. While they had the car off of the dolly to repair a rust hole on the passenger's side sill rail (they cut out the cancer and flush welded a metal plate), I wire brushed and then POR-15 all of the bottom metal parts. When I get it back from the bodywork, I will strip the underside and paint it
Dank Grey Metallic powdercoating looks sweet on the frame. Had the suspension parts done in gloss black, and I have done all of the smaller parts at home (brakes, brackets, bolts, ect.). ZZ4 crate motor with LOTS of billet and Edlebrock parts. Jet-Hot Sterling Silver headers, VB&P Full performance suspension
Old Jul 16, 2006 | 10:25 AM
  #76
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
What you talkin' bout?
For some of us, that's all we do. In fact, I didn't buy my corvettes to drive, I bought 'em to work on....and on.....and on....
Old Jul 16, 2006 | 11:15 AM
  #77
collectskulls's Avatar
collectskulls
To Is anyone else actively restoring?
Old Jul 17, 2006 | 05:48 PM
  #78
corvetteed2shark's Avatar
corvetteed2shark
I just finished my 75 vert and used por 15 it looks like powder coat and costs way less if I knew how to post pictures I would put them on for you good good luck with the resto.
Old Jul 17, 2006 | 09:52 PM
  #79
bwellisley's Avatar
bwellisley
where would be the best deal to purchase the POR 15? I'd like to use it as well. Thanks
Old Jul 17, 2006 | 09:56 PM
  #80
82MDVette's Avatar
82MDVette
I am getting ready to reorder. Just ran out yesterday.
https://prp-porstore.hostasaurus.com/index.html
