Shocks ...?
Old Jun 13, 2006 | 09:44 AM
1970-Bronze's Avatar
1970-Bronze
Default Shocks ...?
Do shocks have a shelf life?
So, does it matter when they were manufactured and how long they have been sitting on the shelf?
Does it effect the performance?
Old Jun 14, 2006 | 09:27 AM
1970-Bronze
TTT
No one?
Old Jun 14, 2006 | 09:36 AM
indy99's Avatar
indy99
From: the land of a never ending frame-off resto-mod. May Visa have mercy on my soul.
With no use the seals have a tendency to dry out causing leaks. By putting those on you risk having to take them off again to replace. I would buy new ones and have peace of mind knowing the seals and mechanisms are in good shape.
Old Jun 14, 2006 | 10:17 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Yes, shocks have a shelf life and will eventually go bad. When I worked at Hunter Engineering, the training guys had a brand new McPherson strut that was about 10 years old. The thing was completely worthless, you could push and pull the shaft to any position you wanted it in. They used it to illustrate that exact point, and to show how useless a worn-out shock is.
Old Jun 14, 2006 | 10:36 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
I think the best way to base it is, how long do they last on a car before you must replace them. Thats their (shelf) life.
Old Jun 14, 2006 | 10:47 AM
1970-Bronze
Ok well when you order some shocks, there's no way to tell how long they sat on the shelf at the supplier before you receive them.
Old Jun 14, 2006 | 05:00 PM
Glass Act's Avatar
Glass Act
Warranty covers that
To Shocks ...?
