$$$ saving upgrade to share.
That's some pretty good research. Nice job, Batman.
I am absolutely confident that my radiator was US made, which is certainly a bonus.
However, had it been made in Canada, Japan or Pango Pango and it did the same job for half the price I would have bought it. If I thought it was cheap crap, as so many here are trying to make it sound like, I would not have bought it.
Foreign made no longer equates to cheap or inferior. Just look at GM vs. Toyota.
Some may refer to it as the Walmart version but in the end I paid less than half of what you paid and I got the same results.
I guess if I'd purchased, or sold, an overpriced item I would do a lot of chest-pounding to justify my overspending too. I would declare anything costing less than what I spent has to be crap. But that claim would be based on nothing more than remorse.
Some members pay $12k to have their Vettes painted. Others pay
$3k. Both cars look great going down the street. Is either one of them wrong?
Mike
SWENSONM you are right on TARGET.
Mike
That's exactly what this thread was "intended" for...
I thank Greg again for the great writeup and heads up on a potential alternative. Thanks Greg...hate your thread got pointed in another direction
No, I do not know Tom DeWitt personally. Although, I did purchase one of his radiatiors and it has worked perfectly, for years, and I received excellent customer service. It must be almost nightmarish to be in competition against companies that are mass producers; no matter what the product may be.
I just wanted to present something else to consider regardless of what we are purchasing. Personally, I am willing to pay more with the belief that I am helping another American family some how some way. Call me old fashioned.
Greg's post, I thought, was excellent; no question. And the better informed we are - hopefully, the better our decision making process.
Y'all have a great day and enjoy your Vettes!
80 Black Vette/Travis
80 Black (not Red) Vette - I just checked!!!/Travis
For the record, I never said Gregs' decision to go cheaper was a bad one. I thought it was well done and documented for others to follow. The thread turned into a "who's better thing" all by itself.
What I'm getting tired of is how hard it is to offer advise, opinions, suggestions, and/or facts without someone taking it personal or being offended. It is for this reason that I would consider exiting this forum and not because someone wants to save a few dollars.
To those that posted support, I thank you.
So, let's let Gregs thread end at four pages and I'll get back to you on the radiator comparison later
I feel sorry for you having to sell on this forum becuase everyone is out to save a few bucks.
****? Maybe...sensible? Absolutely! I get to "do it my way" and save money at the same time
However, if you're on a little tighter budget (and who isn't?) this may be the way for you.
I chose to go with the Summit, American made, fully welded aluminum radiator part number 380331. What ultimately made me choose this route (besides the $$$ savings) was Summit's "Handshake Guarantee". If it doesn't fit, return it for a full refund. No questions asked. That certainly made it worth the try. Free shipping and two day delivery.
The fit and finish are great and the modifiactions were very minimal.
Here's the procedure:
Remove the fan but leave all the belts and pulleys in place.
Remove the radiator support (it's only six bolts and a good time to re-paint it) and do the rad install on the bench, it's much easier.
I drilled two holes and moved the passenger side upper rad bracket inboard one inch. If I didn't tell you, you couldn't tell it's been moved. Original holes are still there so the A/C condenser fits back in as it should. I trimmed the shroud just slightly around the upper hose outlet so the hose would fit and installed a screw-in brass fitting for the overflow neck. I was able to re-use all of my rad support air seals but I also added some self adhesive weather stripping (Auto Zone part number MW78348) between the rad and the rad support to prevent any air leaks. I installed new rad hoses using the part numbers posted here by another forum member. Upper hose is Auto Zone number L-238 and lower hose is Auto Zone number XL-060. I trimmed about two and a half inches off the thermostat housing end of the upper hose and about two inches off the water pump end of the lower hose. They fit perfectly and cleared everything they needed to.
I re-installed the rad support, hooked up the hoses and re-installed the fan, checked for hood clearance at the rad cap (plenty). Filled it up and started it. Remember I'm right on the edge of the Mojave Desert. The temp here today is 106F in the shade. I ran down the freeway for about half an hour and stayed rock steady at 195 degrees. For the return trip I came back through the city in stop and go rush hour traffic for about 50 minutes. Didn't get over 190. Considering the outside temp of 106F I'm very satisfied.
I'm sure my numbers would be much lower if I was out at the coast.
The additional time involved was only about an hour difference from doing a direct replacement brass/copper radiator.
Here is the cost breakdown:
Summit aluminum radiator: $169.95
(free shipping, 2 days)
Handling fee: $9.75
Upper hose: $18.97
Lower hose: $16.99
Brass fitting: $1.99
Weather stripping: $14.99
TOTAL: $232.64
Less than half the cost of other aluminum radiators.
I would recommend this radiator, simple and cost efficient install to anyone. Skill level is very basic, you don't need to be a fabricator and no unusual tools are needed. A couple of wrenches, a drill and a saw or grinder to trim the shroud.
Best,
Greg
. First one didn't fit. Second was Dewitts which was received Friday and installed this weekend. Dewitts is a perfect copy of the original radiator.
