Hello. Are the bumps on the front original or not? This is a question I have had for a long time.I have owned my 68 corvette since 1974. I have never wrecked it but I am about to do an off frame restoration. Tonight I had a "professional appraiser" look at the car for the reason I am going to put antiques tags on it and insure it through JC Taylor.
Some people tell me the bumps are from rivets used to hold a replacement front clip that would have been installed after the car was wrecked.
Others tell me that the bumps are a sign that it is the original front clip and not to have them removed during the restoration.
I am not sure who to believe. Any comments or opinions you have would be welcome.
Below are 2 pictures of the bumps on the front of the car. You have to look hard but there are 2 rows of bumps. One row just below the hood seam and one row,almost unnoticeable,above the head light door.
Thanks for the great advise from this forum. It rocks
Those are from the original rivets used to bond the headlamp sub-assembly together. Not supposed to be visible, but rust causes distress to the structure. I just repaired this problem on a customers '69. I'll post a pic. or 2 if I can find them.
Here the pic. prior to sand-blasting. After blasting, the assembly is epoxy primed and installed .
I use a commercial heat gun set on "Just below sun" to heat the bumps. Using a blunt end of a screwdriver, press the heated bump flush until it cools. You will need to refinish the paint, as this procedure is somewhat aggressive. Start with less heat, add as necessary. After the bumps are flush, clean up the underside of the surround of rust prior to re-bonding the support. Removing the support is the most critical step, as it's easy to rip into the surround if your not careful. This is a 10 of 10 in relative difficulty, so take your time. (I charge a lot to do this job)....
P.S...I got my first Vette (a 68 Vert which I still have) in June of '74. Way cool!
Thanks for the info guys. I was always wondering what caused the bumps. The photos you sent show exactly how it happens. I had always thought that someone wrecked it before I purchased the car.
I suspect that, since you live in a quite humid environment, the rivets rusted and bulged. I think a proper restoration would include grinding them down or removing them in some acceptable fashion.
The front clip is probably original, but they didn't roll off the assembly line with visible bumps...
Now this is an interesting thread. One member has a question about the bumps on his car, and wonders what it is, and another member has a cutaway view of a vette showing where the rivets are located. Nice answer to a puzzling question.
If you do a search either in this section or the C3 Tech section there was a forum member that had the same problem and posted detailed pictures on fixing them.
We just did my Yellow 68, i`m finally going to put it back together after setting for 33 years. If any one is interested in how and what materials we used, E mail me at wallyknoch@aol.com and I can send several pictures of before and after.
Thank you for the correction. I snagged that photo a good while back and obviously mis-labeled it. I can now see the 69 grills.
Either way, it's a really neat display.
I'm going to edit the name and edit my post so the picture will remain but with the correct name.
The only other bbc with aluminum heads was the L-89, but it had 3X2 carbs. The air cleaner is an L-88 piece. The parts are available to build a clone, though!
I can`t see any aluminum heads, but L88`s did have painted valve covers, not chrome. Besides, no one is going to cut up a real one.
I read a few articles on that 69 L88. it is the only black one known to exist(obviously not black in that picture, but by now the car is finished)
the owner has done some other cool vette display restorations as well.
he planned on showing it one season with the skin off, then completing it. it was in a couple vette mags last year....and yeah, it is real.
