pulling motor ?s
Old Aug 27, 2006 | 10:21 AM
garay77n84's Avatar
garay77n84
Default pulling motor ?s
i am about to pull my motor on my 78 4spd,motor needs to be rebuilt, would it be easier to pull motor and tranny or just motor alone?
will be putting new centerforce clutch kit and new motor. i just want to know which way will be easier? thanks corvette forum
Old Aug 27, 2006 | 10:56 AM
kidneyboy's Avatar
kidneyboy
I can't really help, but I pulled both the motor and tranny from my 78 this summer so I just wanted to say have fun!
Old Aug 27, 2006 | 11:14 AM
Dobermann's Avatar
Dobermann
Pull 'em both. I've pulled the engine/tranny from my car twice and pulled both at the same time with no problems.
Old Aug 27, 2006 | 11:19 AM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
It's much easier to reassembel it all when it's out of the car...unless you have a lift.
Old Aug 27, 2006 | 11:42 AM
Bob Onit's Avatar
Bob Onit
Does the crossmember unbolt on the 78 or is it fixed?
Old Aug 27, 2006 | 01:23 PM
garay77n84's Avatar
garay77n84
not sure,once weather permits will crawl under car and look.
Old Aug 27, 2006 | 01:36 PM
kidneyboy's Avatar
kidneyboy
Fixed I think.
Old Aug 28, 2006 | 09:38 AM
vetteonr's Avatar
vetteonr
When I did mine last spring I just pulled the engine. If you're not doing anything to the tranny, just leave it where it is.
Old Aug 28, 2006 | 10:02 AM
76stingracer's Avatar
76stingracer
Both as one unit.
Old Aug 28, 2006 | 10:22 AM
garay77n84's Avatar
garay77n84
not doing anything to the tranny ,but i am going to put a new clutch kit.,did the motor go back in real easy? anything to look for or watch out for? thanks alot
Old Aug 28, 2006 | 10:33 AM
72LS1Vette's Avatar
72LS1Vette
If the car was built with a manual trans the crossmember is fixed. All of the auto trans frames have removeable crossmembers. You have to look underneath to be sure - the frame could have been replaced, trans swap from auto to manual, etc.
Rick B.
Old Aug 28, 2006 | 11:11 AM
vetteonr's Avatar
vetteonr
The clutch kit just bolts right up to the flywheel. Just make sure your flywheel is in good shape, no grooves or warpage. Sometimes it can be resurfaced, but since it's apart, it's best to just get a new one. Make sure you use the alignment tool the kit comes with. A new throw-out bearing is a must also. It should come with the kit. That goes on the shaft of the tranny in the bellhousing......
When you lower the engine in place, slowly mate it to tranny to line up the splines. Wiggle it a little until you feel it mesh, and it should slide right in.
Old Aug 28, 2006 | 01:03 PM
garay77n84's Avatar
garay77n84
thank you very much,should attack this project this weekend.
Old Aug 28, 2006 | 01:35 PM
vetteonr's Avatar
vetteonr
Good luck and keep us updated. It's a lot of work, but when it's done, it's a great feeling.
Old Aug 28, 2006 | 01:59 PM
Bob Onit's Avatar
Bob Onit
Rick B.
I knew that the 73' autos were bolt on and the 4 speeds are fixed but I wasnt sure about the newer years.. thanks
I have never pulled an engine with a standard shift without leaving the transmission attached to the engine.
I dont imagine it's too easy to line up the input shaft on a standard with the clutch disc upon the re-install.
Never tried it though.
Old Aug 29, 2006 | 07:08 AM
vetteonr's Avatar
vetteonr
It's really not that difficult (at least mine wasn't). But then again, I've only done one. The wiggle room you have while the engine is still supported by the cherry picker helps out a lot.
Old Aug 29, 2006 | 02:45 PM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
When I did the 327 in my '68...it went in pretty easy!! Not sure if I was lucky or good. I figured just luck!!!
I never even used an alignment tool. Just bolted the clutch up and used my finger for alignment!! Just be patient and pay attention to details. All will be fine, and when you light it off, it is VERY SWEET music!!!
Old Aug 29, 2006 | 02:53 PM
garay77n84's Avatar
garay77n84
thanks alot.
To pulling motor ?s
