Vacuum Gauge install?
Old Sep 22, 2006 | 01:08 PM
taylorsk8's Avatar
taylorsk8
Default Vacuum Gauge install?
I want to install a vacuum gauge, and i have one, but i want to know where the best place to T of the exsisting lines is. Please let me know.
Old Sep 22, 2006 | 01:12 PM
myoriginal77's Avatar
myoriginal77
Any direct to the manifold connection should work fine. On a 73 there should be 2 available I think. Someone corect me if I'm wrong.
Frank
Old Sep 22, 2006 | 01:20 PM
taylorsk8's Avatar
taylorsk8
So can i splice into the hose already comin gfrom the manifold and be fine?
Or is it better to splice closer to the tank?
Old Sep 22, 2006 | 02:22 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Got power brakes? DO NOT slice in to the power brake line.
Old Sep 22, 2006 | 02:23 PM
taylorsk8's Avatar
taylorsk8
Yes power brakes, thanks for the cautionary measure but I know that already.
Old Sep 22, 2006 | 11:17 PM
7T1vette's Avatar
7T1vette
You can hook the vacuum gage in anywhere you want. It is best to go to the end of a hose [so you don't have to cut into a line]. The gage you bought should have come with some little line adapters and an extra length of tubing so you could hook up however you need to. To see what vacuum your engine is capable of making, disconnect and seal off all lines coming from the fitting on the intake manifold (usually a 2-way or 3-way fitting) then connect your vacuum gage to just one of the ports. Start car (best to be at normal operating temp), set at idle and read the gage. Record that reading (or adjust the carb and distributor for max. vacuum) and re-attach the original lines. Now wherever you hook the gage in, you can compare the results to your "baseline" reading to see if you have a significant leak or not.
Old Sep 23, 2006 | 03:20 PM
taylorsk8's Avatar
taylorsk8
To Vacuum Gauge install?
