Engine stand size
Old Nov 4, 2006 | 09:08 AM
eastltd's Avatar
eastltd
Default Engine stand size
Hi Guys,
I'm looking to buy a stand to mount my 454 on. Can anyone tell me if a 750Lb rated stand will hold this big block or should I upgrade to the 1000Lb unit?
Old Nov 4, 2006 | 09:13 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
A fully assembled BB = 675lb approx. I bought the 1000lb stand.
Old Nov 4, 2006 | 09:23 AM
nihil's Avatar
nihil
Don't use a 750 lb stand. It was very scary when I put the 454 onto it. Maybe if you've got aluminum heads and intake it will be okay.
I promptly went out and got a 1250lb stand. 1000 is probably fine.
Old Nov 4, 2006 | 09:26 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
whats up with your avatar?
Old Nov 4, 2006 | 09:27 AM
eastltd's Avatar
eastltd
Thanks Guys,
That confirms my thinking. The block still has the iron heads on it and will stay like that while I'm working on the frame. Once the chassis is done, we'll start the motor build. Plans include aluminum heads, intake & water pump so the weight will come down eventually.
Ian
Old Nov 4, 2006 | 09:28 AM
nihil's Avatar
nihil
I collect various sorts of communist junk. Why, I don't know. I am no communist -
Yay capitalism!
To Engine stand size
